brake light in dash
ok some time the light comes up but them is doesn't not. Does anyone what i can do it make it just stop it.
Check your brake fluid level. When you take off the reservoir cap, make sure the rubber bellows is collapsed back into the cap and not extended. If it is just push it back in. If the fluid is low, fill it to the correct mark.
When the fluid warms up afterafter driving, it expands and the light goes off. When the fluid cools overnight, it contracts and it will read low. The reservoir has a magnetic float in it that operates a reed switch under it, to bring on the E brake light, when the fluid is low. The rubber bellows can hold the float down to bring on the light, just opening the top and folding the bellows back up, will turn the light off. .
well my brake fluid is filled up all the way. I'm thinking it might have to do with the wires in the back or some where around there.
ok so the brake light comes on intermitently and your fluid level is full? by any chance is it cold where you live? mine use to come on some times when its like 10 degrees out... i think its because i need to change my brake fluid
um the coldest that is get here is about 39
pop the cap of the brake fluid canaster. look at the cap, push the middle back into the cap (pushing the rubber bit back into its origonal shape)
That stopped my brake lite from comming on and felt like an idiot after that. Greg |
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore! Scott & Audrey's Subaru SVX's 1995 Green 1992 Black |
i think it might just have to do with the wire back there.
