Tie rod
Hello,
As you know tie rod of following parts no are discontinued. 34140pa000 34140pa010 (also, tie rod ends are discontinued) So, does anyone know of any parts that can be substituted? Mori |
Re: Tie rod
I've not used this company, but they seem to have some:
https://www.moog-suspension-parts.co...er-tie-rod-end I seem to remember their used to be rebuild kits for that them as well (if you're arm isn't bent). |
Re: Tie rod
I installed the BeckArnley tie rod ends a number of years back. Perfect fit. Have had no problems with them.
Re: Tie rod
Okey. tie rod end seems available. it's good news.
But, my main problem is rod. end seems still okey for now. |
Re: Tie rod
I did come across a full Rack and Pinion set for sale, seems to include the inner tie rods:
https://www.buyautoparts.com/buynow/80-00681_r Seems kind of strange that there are no re-manufactured inner tie rods, but plenty of tie rod ends. Do you know what is wrong with your inner tie rods? |
Re: Tie rod
Remanufactured Rack and Pinion is one of way. but too expensive.
As you say, they will need new rack ends (tie rods) to rebuilt steering rack. Perhaps there are generic similar parts. I found that Toyota Crown (210/214 type) tie rods are very similar. Its screw diameter is 16mm and the pitch is 1.5mm On the other hand, all of my other SUBARU's tie rod is 14mm x 1.5mm. It is not able to use for SVX. https://www.monotaro.com/p/3029/3427/ Parts No is 45503-30150. It's cheap at around $35, so I'll try it later. I'm currently overhauling the brakes on my other car, won't be able to use a lift for SVX until that's done. I'll tri it once my lift is free. BTW, There is some play in the universal joint of my tie rod. |
Re: Tie rod
