Rear bearings...
are these any good... http://replacement.autopartswarehous...0Assy.&dp=true its cheaper than.... http://replacement.autopartswarehous...aring&dp=false
---Travis--- |
thats a good question... i would guess that maybe (big maybe because im trying to make sence of this) that the assly. price is only for one unit and the bearing is for both sides... but i have no idea
they would be easier to replace i would think...
---Travis--- |
thats true it looks like it doesnt need the use of a press w/ the assembly
My guess is that is a stock photo they use for all of their units. I do not recall how the hub looks on the SVX, but I HIGHLY doubt you can get an entire hub assembly for that cheap. It is the bearing only with a misrepresentative photo.
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock |
perdy sure it wouldnt say ahhhhheeemm cough wheel bearing assembly but ill call and post back because that would be a hella lot easier. buy 2 sets so that you dont have to do so much work in a weekend etc, change the grease in one set put it on then when ya have time do the other so you have it on hand, mabie it will be good luck and they will never go out again!
---Travis--- |
