svx dead
Went out this morning to drive my daughter to school. remote did not appear to work, used key, car dead, battery is charged. Transmission is stuck in park.
Last night was cold, which for northern california, bay area was upper 30s. I did drive and park the car late last night and noticed the ABS light on. I recall having a similar incident some time ago which was related to the car pushed against a curb but this did not appear to be the case, anyway I tried to gently rock the car and see if there was a mechanical lockup problem but to no avail. So to sum up the problem: remote won't work, battery good, transmission won't come out of park, and daughter was late to school. Any suggestions on what to look for would be greatly appreciated, by the way I have a complete set of manuals for the car but with the exception of replacing one window cable clip and the drivers side auto window switch have left everything else up to a mechanic. |
So you charged the battery after you tried to start it? Or you just knew it was charged?
It is possible that the ABS light meant that the ABS motor was stuck on and drained the battery. I have had times where the ABS motor got stuck in the ON position. Did not change when the key was removed. I had to remove the relay to make the motor stop. Try charging or jumping it.
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock |
How did you confirm that the battery is good? 'Cos your symptoms add up to one very dead battery.
dcb |
Sounds like a dead battery. Remote didn't work because the car's battery is dead, car wouldn't start because battery is dead, shifter wouldn't move because the shift lock solenoid doesn't work because the battery is dead. Did I miss anything?
You can shift out of park with a dead battery if you use the shift lock over ride feature. On 92's it was as easy as pushing the button near the shifter. On 93 and up you need to pop off a small cover and use a screw driver to access the over ride switch. Dave |
I looked at the idiot indicator on the maintenance free delco battery and it appeared green. Just confirmed that the battery is indeed dead with a volt meter. Thank you for the quick replies and I am some what sheepish that I didn't reseach this problem better before posting. I did thou fine a wonderful site which I will try and visit, maybe to share the tale of five replaced rear axle bearings or the moving idler pulley on a car that was always serviced by "subaru trained" machanics.
Glad you found the problem!
Don't be a stranger.
-Chike
Remember to check out the ABS relay after you change the battery, or else you may be in for another rude awakening tomorrow morning.
KuoH Quote:
HENRY 92 SVX Claret(No More) 12 Camaro ZL1 89 Yamaha FJ1200 07 Yamaha FJR1300 "GO RAVENS" |
The best I tell you! >:O
> > > > >? Console.
Back to the spec book for Dave! Glenn
Oneofthesedays...
