She's a smoker
My SVX just started to develop a smoking problem. Oil coming from the valve covers is the culprit. Anyone have a clue as to how much the gaskets are for the valve covers?
Keith
The member formerly known as Civic_Slayer 1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT 1992 Pearly 187K and climbing (11-91) #964 *retired 1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD Everytime I get into my car, it always reminds me that it has POWER |
Gaskets are cheap. However, doing them is a pain. In my car, it's relatively easy with a lot of open space in the engine bay..SVX..not so much engine room.
You'll need the gaskets (like 3 of them and will want to replace the grommets). Figure about $60 per side from www.libertysubaru.com It'll probably take ya about 3 hours or so per side unless you've had some experience. Definately easier if you remove the battery, airbox, coolant tank and water washer tank from the get go but still a pain. Not something I'd recommend for a novice around the engine as chances are you'll overtighten something and it'll still leak.
The gaskets are cheap...once you add up all the grommets it gets a little expensive. I've currently got on order enough to change 2 engines.
Parts are pretty cheap.... my mechanic charged 2.2 hrs labor.....
~~Michelle ----------------------------------------------- '92 LS-L - copper - 190K miles '94 LS-L - pearlie - 92K miles *still have '92 parts* |
i believe its the rear main seal. mine is cracked too and so is svxfiles'.
What the heck is a grommet?
In the context it's the little metal/rubber seal that seals the valve cover bolts.
How do you get them?
Sounds shady.
