Old 10-24-2007, 06:50 PM
cruisen_15's Avatar
cruisen_15 cruisen_15 is offline
symptoms of bad cps??
can someone tell me the symptoms of a bad camshaft position sensor?? thanks
Old 10-24-2007, 07:28 PM
Wikedjuggalo's Avatar
Rebuilding
Wouldn't there be a Check Engine light popping on? And also the code for it would appear ?
Old 10-24-2007, 07:55 PM
Manarius's Avatar
Manarius Manarius is offline
Poor starting no matter what the temperature of the car is usually the case of a broken/failing sensor.
-Jason
-Obi Wan Kenobi
Old 10-24-2007, 07:57 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
the car won't start...
I seem to remember that Dan had a problem with his that YT diagnosed and fixed....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-24-2007, 08:08 PM
cruisen_15's Avatar
well what controls the ignition, cuzz im having excessive back firing when it has hesitation, no CEL, and no power light is on, im unable to check what the cell meens because when i went to go put one of the two blue wires into the black connecter, the top left 2nd pin wasnt there..... and i did have a CEL for a misfire in cylinder 2, swapped it with cyl. 1 and ran good like it was running with 6 cyl., and no CEL, but still getting a bad hesitation...
Old 10-24-2007, 08:14 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
What year is your car?
ODB II systems that can indicate which cylinder is mis-firing can't be self read with the blue wires, you need a code reader
ODB I systems, can be self read with the blue wires, but won't indicate a specific cylinder misfire.
Old 10-24-2007, 10:38 PM
cruisen_15's Avatar
i have a 96
