struggling to reset c/e code
Just replaced an O2 sensor..had a 32 code and I tried both ways to reset the code:
1) placed both pins in upper left 1 and 2 pinholes, started car, shut car off, removed one pin and then turned car on but not starting it....to read the blinks.....error still there. 2) with pins removed , turned car on but not starting it, turned on headlights, then disconnected the neg. batt. cable.....and waiting about 30 secs.... then proceeded to turn lights off, take key out, connected batt. cable, stuck pin in second hole on upper left and proceeded to check the codes again.....no luck still old code in there. I did let the car run until normal op temperature, but haven't driven it around yet. Can someone tell me why this issue I cannot resolve? thanks |
Re: struggling to reset c/e code
bump....anyone know how to resolve this?
I drove the car and no issues last night...no c/e light on dash, I just can't erase the old code |
Pull the negative cable. Turn the key to full on, but not start. Turn on the headlights {only takes a second}. Hook it all back up and check for codes.
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
disconnect the negative terminal all night and reconnect it in the morning and it should be gone
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
This is how I was able to clear my TPS code and both o2 codes
Keith |
(also helps if the problem doesn't still exist) Keith |
I will try redlightningsvx suggestion leaving it disconnected overnight. I can't think of anything else to do. |
I left my battery disconected for a week and nothing eraced till I got the problem corrected. I had a 37 code, replaced the 02 and did not correct the problem. After I got it corrected, tried the 2 blue wire thingie... did the battery disconnect thing... Did the battery disconnect, turn ignition switch on but did not start engine as per instructions (how am I going to start the engine with the neg battery cable disconnected) next step headlights! Hope you get it worked out ok! Keith |
