running with compressor off
i had my a/c compressor rebuilt last year (dont ask me why i did) and have a warranty which is still good. however, the mechanic at the shop told me that i wouldn't be able to run the car with the compressor and compressor belt off the car. i dont believe this is true. the pulley has been changed to the one piece/lightened at motorsport. and i'd prefer to still drive the car while the compressor is in...re-rebuild.
would there be any damage/problems with running the car with the compressor and compressor belt off?
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
no infact you can get better gas milage doing that
Just make sure the hoses are tied down from flopping around.
oh and there is tape around them to that no dirt gets in the system
Yeah, you should have no problem running without a compressor. A lot of Legacy guys remove theirs because they don't need them or want them. You can even use the stock crank pulley. In your case, do what was said above;
Remove compressor Tie down tubes Cover them so they don't inhale anything Remove accessory belt Just be careful that you don't try to turn on the A/C system or bad things could happen (ie. don't use the auto temp system and don't turn on the defrost).
What the heck would that hurt?? Just because the compressor field goes bad (hypothetically) the rest of the system should go up in smoke?
