weird noise from center of car
the noise is coming from the center of the car. it sounds like a band saw going. it gets louder as u drive faster. no difference if u put in neutral while driveing. does not make that sound while in idle
1992 pearl svx (given away) Custom Cold Air Intake Stage1 Shift Kit Brembo Cross-Drilled/ Slotted Rotors. Front and Rear 4.44 gears now in better hands of svxfiles |
Something rubbing on the driveshaft?
My bet would be e-brake cables or one of the heat shields on the drive shaft.
Todd
Down to none |
svx.net novice says wheel bearings. I've driven my svx for one month now. I replaced the RR wheel bearing. Now I have to replace LR wheel bearing. Both sound as if they are coming from the middle of the car. Sounds exactly like a band saw, noise is speed sensitive, and present regarless of Neutral or Drive! Maybe you've already replaced them but I just thought I'd throw in the obvious.
it is coming from the front of the shifter in the car while driveing. when u put your hand down on floor infront the shifter u can feel a vibration .
That sounds like a heat shields are loose to me. I'd check the welds on them.
Or maybe try feeding a piece of wood underneath....If it comes out in two pieces, then it's definately a band saw...lol |
