Oh No, What Did I Do?
Well, I replace the PCV valve today, by removing the intake mainfold. I also removed the alternator and that large plastic ductwork at the back of the engine with all the hoses attached to it. While I had that off I spayed the throttle bodies with a carb cleaner. When I put everything back together and went to start the engine, it immediately rev'd to around 3K rpm, ran extremely poorly, and then shut off. I also heard some odd high pitched whine when it was running. I tried to start it a few more times, but each time it would run extremely poorly; I had to keep the accelerator depressed to keep it from cutting out. I checked the connections to the alternator but they look OK.
So. My 1st thought is that maybe I connected some of the hoses to that plastic ductwork wrong. My second thought was that maybe it had something to do with the carb clearner. Other than that, I dont know what I may have done wrong. But I'm real concerned about this. So any help would be greatly appreciated. Thanks. Larry |
Re: Oh No, What Did I Do?
check to make sure you don't have a leak at your intake. Either vacuum hoses or where you unbolted it at the gasket.
How long did you let it run with the carb cleaner? it will take a little bit to remove it
I kept the accelerator down for maybe a minute, between the 3 times I started it. i was concerned about running it longer, thinking that maybe I'm exacerbating the problem. You think I should just let it run poorly, keeping it at a few thousand rpms for a few minutes?
I just went back out and ran the car for a few minutes. It did run better, no more whine, but I still needed to keep the accelerator down to keep the car at around 2k rpms. But when I let up, it would run rough at below 1K rpm and then cut out. wonder if it would hep if I took it for a drive. May try that tomorrow.
Sounds like something that was connected is not, recheck all hoses and electrical connectors, carb cleaner should be all gone in seconds of running, may have dislodged some gunk and got stuck somewhere else??............G
I thimk ther4 I an, what? huh! 03 Baja. 05 Baja turbo 92legacywagon"snow" 94legacywagon"whinny" 84Brat"huey" 92svx"samantha".pearl 92svx"sabastian"4.44 silver 92svx"sabrina".ebony 05legacy gt limited "Moon" blue. 06 Subaru legacy gt limited. |
If that is the case, it is probably just the carb cleaner wreaking havoc on your idle air controller. There is a reason to use throttle body cleaner rather than carb cleaner... It may work itself out or you may have damaged the plastic valve mechanism in the IAC and are causing it to jam... Gonna have to drive it and see if it finds the idle again
Tom |
I would reclean your TB with TB cleaner, then take it for a good freeway drive. Sometimes gunk can be dislodged from one place and become stuck in a worse place down the line, like the idle valve as mentioned. A long high-speed run should also help burn any crap off of the O2s.
I would also assume it is the IAC that is causing this problem.
My mechanic told me long ago, that this specific unit should not be cleaned.. ever. Once you try to clean it, its 'internals' just get messed up and it will never function properly. You used the carb cleaner which does a job even better than thinner with metal surfaces. I second YT's opinion in this..
I'll try the throttle body cleaner tonite. Can the idle air control solenoid valve be removed and inspected to see if I screwed it up?
did you use new IM gaskets when you put it back together? im thinking a vacuum leak is a possibility...
94 Acura Integra GSR 97 Legacy Brighton - EG33 Swap still in progress 03 Silverado 2500 - Duramax |
