Old 05-07-2019, 07:58 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Re: SVX Engine cooling "Again & Again"
https://www.facebook.com/danielh.nal...ll0AEGr-5IWHk0
Harvey
Fortunately no police on those back roads. Far too many roads and way too few police. Stay off the main connectors and you’re good. Attached is a video of one of my early Sunday morning drives. So much fun.
Last edited by shotgunslade; 05-08-2019 at 07:45 AM. Reason: trying to get video to work
Old 05-07-2019, 08:00 PM
Harvey
Old 05-07-2019, 11:25 PM
oab_au oab_au is offline
Finally got it to play.
The engine sounds quieter than it did when Tom first started it up, it had a lot of tappet noise. Suspension still quite solid over the jump.
One Arm Bloke.
Tell it like it is!
Old 05-08-2019, 07:46 AM
Fixed link in previous post so video should come up easily
