Old 08-31-2009, 01:38 PM
alia176 alia176 is offline
How important is the "Tank Surge" under the intake?
The nipple on my "tank surge" is broken and I was wondering if I can do w/o this item? What exactly does it do? It's a plastic box with nothing inside so is it a simple container to prevent a vacuum surge of some kind? If it's critical, I can try to figure out a way to fix it. This is the second unit I picked up from the junk yard but the nipples are ever so brittle.....
There is a check valve in this circuit so if I were to bypass this plastic box, I will reuse the check valve and run the vacuum lines like they're suppose to run - just no "tank surge" plastic box in the circuit.
It's item #1 in the diagram below
It's the black plastic box in this pic
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 08-31-2009, 03:28 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: How important is the "Tank Surge" under the intake?
no tank surge, no IRIS valve in the intake...
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-31-2009, 03:37 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Originally Posted by alia176 View Post
The nipple on my "tank surge" is broken and I was wondering if I can do w/o this item? This is the second unit I picked up from the junk yard but the nipples are ever so brittle.....
< Insert random nipples joke here >
Old 08-31-2009, 05:22 PM
oab_au oab_au is online now
The system produces the strong torque from 2200 to 4000 rpm. It changes the inlet manifold from a dual Inertia system to a Plenum resonate system, by using vacuum to open the butterfly between the two halves.
The vacuum tank is necessary, as when the throttle is wide open, there is no vacuum in the manifold to work the valve. The tank stores the vacuum to open it, no tank, no low speed torque.
Old 08-31-2009, 09:44 PM
Copy that, I fixed the nipple A simple 1/8" plastic hose mender and plastic epoxy weld took care of my broken nipple (ok, I'll stop with the nipple jokes).
Does anyone have a closeup shot of the IRIS valve? I need to make sure that my orientation is proper before I re-install the intake.
Thanks for the inputs.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 09-01-2009, 12:59 PM
gbianchi gbianchi is offline
I can't not say this, brittle nipples not good, firm ones are just fine!......Sorry that isn't helpful but the question seems to have been answered..........G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 09-01-2009, 05:00 PM
Yes, yes, I have to agree whole heartedly
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
