Old 12-17-2006, 03:00 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
fuel pump relay
can anyone tell me where its located ?
I did a search, came up gooseeggs
Ill going to search my manuals tomorrow while
Im at the shop, but wanted to get a little more info
on it if possible.
thanks
Dayle
Happy Holidays everyone
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 12-17-2006, 03:13 PM
on it if possible.
thanks
Dayle
Greetings Dale,
My SVX, which is driven from the right hand side, has it on that side, under the dash alongside the main relay. This may give you a clue.
Merry Christmas, Trevor.
Old 12-17-2006, 03:36 PM
Originally Posted by Trevor
Greetings Dale,
so for you its on the drivers side under the dash
when you say main relay, are you talking about the
main fusebox ? Ill go check mine out, thanks.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 12-17-2006, 03:48 PM
No not the fuse box containing several relays. There is separate individual item, titled in the manuals as "Main Relay". It switches a lot of stuff and it is not good when it is stuffed.
Old 12-18-2006, 12:45 PM
dynomatt dynomatt is offline
Again a RHD comment sorry, but both the main relay and the fuel pump relay are attached to the back of the ECU mounting bracket.
Don't have a photo of them at the moment sorry.
I wonder if the LHD is that different.
Have you seen an ECU in place? Does it look like there's two relays stuck to the back of the bracket? If so, that's them, with the big brown one being the main relay.
Old 12-18-2006, 01:01 PM
It is on the drivers side on our cars also (so the same side, but the opposite ), attached to the back of the ECU.
Not sure what your after, but there is also a fuel pump resister and fuel pump modulator under the rear deck, between the speakers. Both of them are also needed or the fuel pump won't pump.
Old 12-18-2006, 01:38 PM
Which is why I had so much trouble getting fuel to FrankenWedge, when I stuffed that EG33 into it...
Old 12-18-2006, 02:19 PM
I assumed the fuel system was the stock XT6 system??
Old 12-18-2006, 02:27 PM
Yes, but I had to tie into the SVX ECU to trigger it
Old 12-18-2006, 09:17 PM
just a stalling problem Im trying to track down...
but after checking it today, fuel pressure stays high
even after it stalls..
so it must be electrical...
thanks guys
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 12-19-2006, 04:32 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Also check your vaccum lines.
Old 12-19-2006, 04:58 AM
thanks guys
Re-seat the connectors on the crank sensors.... (both of them)
Old 12-19-2006, 02:59 PM
cdigerlando cdigerlando is offline
Relay
Dayle:
Sorry to reply so late. The relay is very easy to find. It is right behind the ECU on the drivers side. It is a cylindrical silver relay, next to a cylintrical black relay. PM me if you need to do this. I have more info such as wire colors and I could even do pics. I recently configured my relay to run off of my Tec II instead of the stock ECU, so I am very familiar with this arrangement.
Take Care
Chuck D.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 10-16-2011, 09:34 AM
Austin Austin is offline
Re: fuel pump relay
For anyone interested, I'm picking up one today from Advance Auto Parts:
BWD Relay Part # R3054Z
I'm sure it can be found at any parts store, but I wanted to post this so people could see a picture of the actual part. Also, apparently it's a REALLY common relay as it's used in a ton of common makes (Toyota, Honda, Mitsubishi, etc.)
(not to be annoying, rather to be helpful, I'm going to cross post this in some other fuel pump relay threads just in case anyone is searching...)
FWIW, turns out it was a loose ground wire on the FP module in the trunk.
Austin
__________
'97 LSi Ebony - daily driver - mostly just needs body work [couple o' rust holes, door dings, and peeling clear (of course)]
'96 LSi, Laguna Blue (retired - soon going to a new home)
'89 XT6 5 speed (Gone but not forgotten)
