Old 07-13-2006, 04:25 PM
Originally Posted by Beav
When I read questions about torque specs I have to remind myself that many don't work with this stuff as much as I do. Seriously, the only things that get measured by me are head bolts, rod & main caps and wheels. Oh yeah, and the lower lateral link bolt on the rear hub. I can't recall the last time I saw my inch/lb torque wrench...
My dad's the same way. If I didn't use his torque wrench it would almost never get used.
Old 07-22-2006, 10:54 PM
redsvx94 redsvx94 is offline
Hi All,
I just wanted to report that my overheating problem has been fixed. While I'm changing the water pump, I have done a boat load of preventive maintenances with it. I would like to thank all who have helped me with diagnosis here!
I have some quick questions. I tested the thermostat operation for both of the new one and old one. Both seemed to be start to open at around 180F not 170F as they were specified. Also at that temperature it is opening only about a tenth of inch. Are these typical of Subaru thermostat?
After the repair, my engine temp gauge seems to be solidly staying just below horizontal position. I also paid particular attention in cleaning and flushing radiator and coolant path so that my engine cooling system would run more efficiently. (I haven’t changed the radiator, since it is rather expensive and water seemed to be coming out well when it was flushed) But when I go near the engine or pop the hood after a couple of hours of driving, I just feel that this car is running considerably hotter than other cars I drove. I just wonder whether SVX is supposed to operate at higher temperature than most other cars or using lower temperature thermostat would help running cooler?
Old 07-22-2006, 11:41 PM
Originally Posted by redsvx94
Hi All,
Your " thank you" is a worthwhile gesture and much appreciated by all I am sure.
The fact that you physically sense that the car is running hot does not surprise me. When I first got my SVX I had the same misgivings. By way of comparison, they are a hot beast and retain their temperature as you have noted. (i.e. are not )
Old 09-06-2006, 02:20 PM
cdigerlando cdigerlando is offline
Hi All,
My SVX has always seemed to run hot from the under hood temps, but I have never had engine overheating problems until now. Thanks for sharing your experiences with us. I may go ahead an replace my water pump. That is the last thing to do. I also got a block tester. As long as I don't go to a major boil over, I don't get any CO in my coolant. So the water pump will be the last thing that I try before changing the head gasket.
Take Care
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
