Old 08-02-2005, 10:26 AM
surfer63 surfer63 is offline
Replacing trans... other parts to replace too?
Hello,
The transmission failed in my '92 SVX and I purchased a rebuilt one with 10K miles on it. Can you guys recommend other repairs/upgrades I should do while everything is apart? For example, should I get an aftermarket transmission mount? Replace any bushings, that kind of thing? Also, are there any upgrades I can do to help this one last for a long time? (besides the obvious: external cooler)
I'm basically want to take advantage of any recommended repairs/upgrades while everything is apart. Thanks in advance for your advice...
Matt.
Old 08-02-2005, 01:47 PM
rbalach rbalach is offline
Have you read about installing a transmission cooler ? If not do a search and you'll find quite a few posts.
Old 08-02-2005, 02:50 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
maybe a new or rebuilt torque converter. definately make sure all the lines are properly flushed and consider an extra filter. personally, i like to change the mounts, etc. while i have them out anyway.
Old 08-03-2005, 12:30 AM
pavanbabut's Avatar
Originally Posted by surfer63
Hello,
Matt.
The good upgrade to consider is to go with a synthetic ATF and also install an external tranny filter. Yeah its a good idea to change the bushing mounts if the older ones are too worn out. Its always better to change the internal filter tooo.
Good luck on the new tranny.
-Pavan.
Old 08-04-2005, 11:46 AM
dromano's Avatar
dromano dromano is offline
source/warranty
Hello,
Matt.
What is the history of the rebuilt tranny? Does it have a warranty?
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 08-16-2005, 03:54 PM
None were made specifically for the SVX and I'm not sure if anyone made one for the Legacy/Imprezas either.
If there is enough demand I will see about getting a group buy together for tranny mounts for our cars.
