Old 04-02-2005, 08:15 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
O2 sensors
OK, dumb question, but staying on the safe side so I don't have to go crawling under this thing again.... At least until next weekend.
Are both O2 Sensors the same? IE-> Interchangeable?
And do most of you guys stick with OEM, or go a different route?
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 04-03-2005, 08:27 AM
Phil, don't know for sure, but I am pretty certain both are the same. You can easily check this out on www.subaruparts.com, as I expect it will show the same part number for each.
There is one fundamental difference between OEM and spurious. [Aside from the generic one being generally maybe 20% cheaper]
The OEM one will simply plug straight into the connector close to it on the loom, when you have it screwed into place. With the generic type, you have to be sure you have the same number of wires, three from memory, and you have to splice them to the loom, as it will have no plug, or the wrong plug.
Phil in the UK did his with the generic ones, and used a handy trick. Having spliced the wires, he wound the sensor and wires backwards a certain number of turns. This meant that while he was screwing it into the socket, the wires were un-winding, and did not tighten up too much.
For my money, you would be better off paying the price of the OEM ones, and plugging in.
Old 04-03-2005, 12:56 PM
blacknite blacknite is offline
Phil They Are Both The Same Stick Around With The Oem. That Why It You Don't Have To Mess With The Connectors..... Like The Stuff You Have Now In The Knew Car!!!!!. By The Way The Only Dumb Question Is The One That Is Never Question!!!!!!
Old 04-03-2005, 02:08 PM
gsodonis's Avatar
gsodonis gsodonis is offline
Sensors
The stock OEM sensors are not the only ones with the correct connector. You have four options (the four below are available from www.oxygensensors.com with free shipping over $50).
OEM (Denso) - Plug and play. Around $96 ea. ($130 each at the dealer)
Aftermarket (Bosch) - Plug and play. Around the same as the Densos.
Aftermarket (Walker) - Plug and play. Around $69 ea.
Aftermarket (Walker) - universal where you have to slice in the connector.
The Walker seem to be the same quality as the Densos (Japan) and the Boschs (Germany), but being made in the US, they're a bit cheaper - no exchange rate to deal with.
I have the Walker plug and plays and couldn'e be more pleased. With the money I saved, I bought the O2 sensor socket set.
Old 04-03-2005, 03:14 PM
Are You Having Problems With Them??? They Usually Last At Least 60k Miles And Your Are Not That All, And Both Of Them Look Like Have Been Replace...
Old 04-03-2005, 04:01 PM
Yeah, having problems. Same problem. Got it back from the dealership who fixed my speedo gears, and as a bonus, threw in a leaking exhaust and a rough ride. All for just a thousand bucks! What a deal!!
Took it back, and they owned up to no problems when the car was brought in, but they weren't going to replace the O2 sensor, because the exhaust was corroded. They said they would replace it for free on a new exhaust system which they will gladly provide for $2,400. Again... What a deal!!! Dayle's performance system is only $1,700.
I'm ripping the exhaust out of the '94 and putting it in there. Since the '94 is a Vegas car, it's coming out pretty easily. I'm not looking forward to getting out the one in the MN car.
Thanks for all the replies!
Robert
Old 04-03-2005, 04:53 PM
Weasel 22
looks like I'l be needing some new exhaust components soon enough..I hear a slight leak..somwhere towards the middle..I wont be going to the stealership..after that price quote..I'll source one of our exhaust shops here in town for some custom work..wont even come close to that price range..jeez
Old 04-03-2005, 08:12 PM
The Stealership!
I'm picking up on that one. Las Vegas' only Subaru dealer will now transform from the Findley Dealership to officially the Fiendly Stealership.
I think in the 5 weeks I bought this 92, (at an excellent price), I've invested a good 2 grand on fixing it up, and I'm not even close. If there's a gasket, this poor thing is leaking there. That's why I never paint these things. I leave it for last, and last never comes.
Robert
Old 04-04-2005, 10:33 AM
let me know if you need any help.... but if you are swaping some of the exhast don't mess to mutch with the O2 SENSORS THEY ARE VERY SENSITIVE..... LET ME NOW WHAT EXACTLY ARE YOU DOING.... I WOULD HATE FOR YOU TO WASTE MONEY..... SPECIALLY AFTER SPENDING 1K.....
Old 04-04-2005, 11:12 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
careful too, even an exhaust leak in the system can
cause the 02s to throw a code.
Btw, our Bosch 02s we sell use OE plugs
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
