Old 11-25-2004, 02:02 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Thumbs down hood latch doesnt latch
well i was outside today just kinda tinkering around with the SVX, i popped the hood to check out the battery and then closed the hood but, i noticed alittle bit of space between the waterfall grill and the hood. i can close the hood and then open it back up with the little hand latchin the engine bay, but the latch that works with the interior pull handle wont latch. any suggestions would be nice, thanks in advance.
dustin
-Dustin
Old 11-25-2004, 05:07 PM
zavikan zavikan is offline
My problem
My svx was like that when I got it, but that was because the bracket the latch mechanism was on was bent in, so it wouldn't line up properly. ended up pulling it out straight, and no problem. seeing as you didnt DO anything to it, I doubt its it, but check to see if its lining up properly.
Old 11-25-2004, 05:27 PM
My problem
Old 11-25-2004, 05:31 PM
Try spraying the mechanism with a lubricant like white lithium grease.
