Old 05-04-2004, 02:48 PM
mbtoloczko's Avatar
sans SVX
driveshafts: center u-joint style vs center CV style
I've been trying to figure out whether the SVX driveshaft with the center u-joint or the center CV joint are more suited to high rotation rates. The center u-joint style makes the rear portion of the driveshaft into a double cardan joint, and from what I've read, unless they are very precisely aligned, these are susceptible to vibration at high rotation rates. I haven't been able to find any info on the center CV joint style. Has anyone researched this area before and found any useful info?
Mychailo
Visit my locker
Old 05-04-2004, 03:22 PM
lee lee is offline
Not sure what you've read, but just in case...
http://hostingprod.com/@aa1car.com/library/cvjoint1.htm
http://www.4crawler.com/4x4/CheapTri...line-101.shtml
http://www.engin.umd.umich.edu/ceep/...MidYear00.html
Old 05-04-2004, 03:32 PM
mbtoloczko's Avatar
sans SVX
Thanks for the info. I followed those links and also found a bunch more.
Mychailo
Visit my locker
Old 05-04-2004, 03:50 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
The CV style shaft will provide a smoother ride at high speeds. In a ten year old car, will it make a difference? Probably
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 05-04-2004, 11:21 PM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
my U joints work fine on my 95 L
SV What?
Old 05-05-2004, 07:15 AM
GreenMarine's Avatar
From POST-***** to LURKER
My driveshaft sucks!!!!!!
Old 05-05-2004, 08:52 AM
mbtoloczko's Avatar
sans SVX
Have you determined what's wrong with it? Is it not properly aligned? Did you use that SmallCar spacer and extension for the mounting point, and if so, is that the cause? Are the u-joints completely trashed?
Mychailo
Visit my locker
Old 06-29-2006, 12:33 PM
nysvx10 nysvx10 is offline
Are the two types of driveshafts interchangable between all years?
Old 06-29-2006, 05:37 PM
dynomatt dynomatt is offline
Do you guys mean driveshaft that joins diff to hubs?
Or do you mean tailshaft which joins gearbox to rear diff?
Do I need to scrub up on my US lingo?
Old 06-29-2006, 06:11 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Up here, where it's cold in December, axles transmit power from differentials to wheels and driveshafts transmit power from transmissions (gearboxes) to differentials.
Old 06-29-2006, 06:20 PM
Arrow
Thanks Beav...I suspected as much, but thought I should clarify.
I had visions of driveshafts (axles to you) like old Datsun's, that used uni joints and I was a bit worried that SVX's had those...
But now that you're talking about tailshafts (driveshafts to you) are you saying that later model ones have cv style centre joints? That's interesting, and I haven't seen that before...even on new Subaru's.
Old 06-29-2006, 06:52 PM
Beav's Avatar
Not as old as Randy
Mychailo,
I've been fussing with mine since I bought this particular car. In my opinion, Subaru should have placed a cv at the front position. When a shaft that uses a cv joint at one end and a cardan joint at the other, the cardan joint needs to be situated as close to 0° as possible. The rear diff joint sits at 0-1°, as does the center. This is just fine, since cardan joints need to have complimentary angles within a 1° tolerance.
The problem with the SVX, and maybe with most Subarus, is the ridiculous angle of the engine and transmission - necessitated by the front differential and longitudinal powertrain mounting. And the distance of the engine ahead of axle centerline. Front overhang vs. angle of attack vs. xx oil pans permanently attached to 7-11 curbs, not to mention the lower bellhousing plowing into every sewer lid in town, ala Mangusta.
If mine is an indication of all/most SVXs, there is a 6½°-7° angle at the front joint. Now, if the front joint was at 1° and the center was 6°-7° with a cv joint and the rear remained at 1° all, would be fine. The only problem with this setup is that if the engine/transmission remained in their original position the center joint would probably be several inches below sea level.
Now if you keep the engine/trans angle at 6°-7° and lift them straight up and cause the front shaft to equal that angle, <>1°, the center cv joint will work properly. I suspect that's why the early cars have them located there. Later, I believe someone decided the center joint was a good place to get cheap. Funny, it was about the same time the ECU gave birth to a speed-limiter.
Anyway, I've been curious if any of the '94 and up drivers have noticed a little 'wiggle' as they slow to a stop, somewhere around 1100 rpm. It only lasts for a split second, maybe 2-3 wiggles/vibes. I know it's the front u-joint, I've changed the operating angle several times and the vibe has changed, stronger/weaker & speed.
By moving the angle I've also cured some high-speed vibes the car has had since I first bought it. Currently I'm torn between moving it more or just replacing the front cardan joint with a cv joint. It's close to being as smooth as my original '92 and the '92s I've recently driven, but not quite perfect.
Discussions?
Old 06-29-2006, 06:55 PM
Beav's Avatar
Not as old as Randy
Matt,
If you peruse SVX parts on ebay you'll occasionally see one of the older shafts with the center cv joint. It's a booted, ball and tulip plunge joint (similar to the front axle inner joints) instead of the more common double-cardan style.
Old 06-29-2006, 07:07 PM
mohrds's Avatar
I think Beav is on to something. I'm not sure how one would go about getting a front U joint replaced with a CV joint, but I think it would work.
The only potential issue is that the Driveshaft (propeller shaft to be Subaru-lingo accurate) spins at 3.54 times the speed of the axles. I'm not sure how the grease would hold up being forced to the outside of the joint. You'd have to use a ball and cage setup like the center CV joint on the LSi has.
BTW: I just replaced my U-joints and center CV joint with parts from www.rockforddriveline.com
How-to to follow when I get the time.
PS: the "1100 RPM" vibration gets worse as the front U-Joint starts to stick and will eventually shred the tranny mount which makes it really jump around when you slow down
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 06-30-2006, 04:23 AM
Beav's Avatar
Not as old as Randy
Also, when under power, torque reaction from the front axles lifts the engine and compresses the trans mount, further increasing the front joint angle.
