Old 09-13-2007, 08:55 AM
Crysis Crysis is offline
AK Rowdy
Send a message via AIM to Crysis
Front End Shaking!
Hey,
Well its been a couple of months now since I noticed my front end shaking and I am having a hard time diagnosing the problem. I replaced the cv joints, got my wheel's aligned and balanced, and now im stuck. The shaking is worse at lower speeds, roughly around 40 mphs and seems to slow down around 65ish. I am starting to think it might be my front differential since i get an occasional binding when i turn...does that sound right? or could it be my steering rack?
P.S.
I have taken it to two suspension shops and they don't see anything wrong with my car....
The shaking is getting worse as the days go by so i would like to figure out whats wrong with it as soon as possible. Let me know what you guys think
Oh and something is rattling when I go over bumps, so it puzzles me that two suspension shops cant find anything loose... :/
Thanks,
Aaron
Old 09-13-2007, 09:10 AM
Occasional binding is going to be my guess... The whole car shakes when the transfer drums bind up.
Old 09-13-2007, 10:20 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
When my front differential bearings were toast on the truck, I would feel every bump and things felt so rough...but the truck drove good most of the time....very little vibration, just alot of sloppyness turning and going over bumps.....
I'm thinking you have a bent rim on the car....does your steering wheel shake?
1995 Subaru Svx L / AWD
Old 09-13-2007, 06:03 PM
nick_kas nick_kas is offline
My car was doing that and I replaced the front u joint. It runs like it's brand new. The u joint is like $30 so it is worth it to look at it. It's under the exhaust.
Old 09-13-2007, 07:45 PM
AK Rowdy
My steering wheel shakes, but the shaking is only periodically is bad...other days its just a minor shake. Did you steering bind up before you replaced the u-joint?
My rim could be bent, but wouldn't the problem be fixed if I rotate my tires to the back end?
Old 09-13-2007, 07:57 PM
Manarius's Avatar
Manarius Manarius is offline
If the rim was bent and you moved it to the back, you wouldn't feel it through the steering wheel...
Maybe it's the brake pads riding over warped discs?
-Jason
-Obi Wan Kenobi
Old 09-13-2007, 08:23 PM
AK Rowdy
my rotors are really warped...hmmmm any suggestions on what I should replace them with?
Old 09-13-2007, 09:36 PM
rotors that are not warped Race concepts has good slotted and dimpled rotors
Old 09-13-2007, 11:40 PM
subru92svx subru92svx is offline
Send a message via AIM to subru92svx
I installed my stolled and dimpled rotors from Raceconcepts today and they are very nice. I would definitely recommend them.
Old 09-14-2007, 07:13 AM
AK Rowdy
Just got done purchasing me a pair
Old 09-22-2007, 11:55 PM
lilbrudder lilbrudder is offline
i can make it on my oooowwwnn!
nick kas, what is this u-joint you are talking about? what does it connect to? what does it do? and where can i get one? if it's made of rubber, mine is most likely bad and i got the shakes too.
Old 03-23-2013, 08:55 AM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Re: Front End Shaking!
My car shakes at highway speeds and when I'm turning at 50-70 it shakes violently. Any ideas? I think worn suspension Nd or worn steering components but not sure.
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 03-23-2013, 08:41 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Also check if your struts are leaking.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 03-24-2013, 07:38 AM
immortal_suby's Avatar
Thread Killah
Check the inner and outer tie rod ends
Locker Link
2015 BRZ Limited 6MT
