Old Hood Struts Wanted
Does anyone out there have a bad set of hood struts? I want to do a replacement aftermarket assembly and need the bottom brackets to cut off of the old struts. I don't want to ruin my color-matched originals.
If anyone has the stud bolt with the ball end that attaches to the top of the strut let me know as well. Just post or send a PM Thanks as always. .
John I still got the set I picked up at Reading.... $400 and they are yours
Tom |
Just let me know how u want me to send them and they are on their way
Tom |
Wonderin'... What's wrong with the ones you have?
I'm going to transplant them to my son's pearlie.
I will be doing the aftermarket strut mod. My new hood struts are already painted polo green and clearcoated. Just need the brackets... An sv-xcessive mind never rests .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 04-27-2007 at 10:11 PM. |
I just found a source for what may be some more appropriate AND more affordable struts, as well as the ball studs, if need be.
We could use to get some failed stockers in circulation, though - both hood struts and trunk struts, or at least the brackets, because the ends will be necessary for a one-time conversion. If anyone has any... please PM. The 120-pounders from the hood How-To are (as some of you found out at Reading) stronger than they need to be. EDIT: A single 120-pound strut holds the hood up nicely, but it drops pretty well down low, which is fine. I'll try a pair of 90-pound struts (the next size down, followed by 60). Much Dremellage in the basement is producing results for the trunk! Details to follow... EDIT: I'll compile all of this somewhere more useful, but I'll fill this space for now. I just ordered a pair of 90 lb. struts for the front, and (after measuring the rear strut I removed) a pair of 80 lb. (!) struts for the back. The 80 lbs seems high until you hear this - the measurement I took was 50 lbs. It's worth a crack. This, along with some experimental ball studs, and the experiment continues...
Disclaimer: The above post is on the internet. Last edited by LetItSnow; 04-27-2007 at 07:52 PM. |
I will check to see if I have any worn out ones.
I ordered them online, so no NAPA P/N... They'll be here next week, and I'll test 'em out right away, so you can paint the right ones the first time.
My trunk brackets on the right side are sawed off and ready to go!
Still looking for a set of worn-out hood struts (mainly for the mounting brackets. Anyone have them let me know.
I just sent you a pm.
MOMZSVX 92 LS-L parts 94-LSi My baby 95-(AWD) polo green T-Boned |
I think I still have the old ones from the Claret lying around somewhere. Let me know if you're still looking for some.
Rebecca 92 Claret SVX LS-L (180k) 09/91 #5,732 06 Suzuki Boulevard M50 7k 68 Cadillac Coupe DeVille (70k) Storage/hibernation for now. Past SVXs: 94 SVX Emerald Pearl FWD (Sold) 96 SVX Bourdeaux LSi (Sold) 92 Pearl SVX LSL "Stay Puft" 5MT (140k) #148 (RIP) 95 Brilliant Red SVX LS (162k) 12/94 #564 "Killer Tomato" (RIP) |
