Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Transmission and Drivetrain
Old 05-01-2005, 06:11 PM
Jnthn_Sctt Jnthn_Sctt is offline
Question A slightly different Tranny Thread
Ok, I'm going to have to replace the tranny in the next 12 months or so. My question is, (No I'm not gonna switch to stick, or 4.11 or 4.44, although they are tempting.)
What I'd like to know IS: would it be worth sourcing a Euro spec Tranny with the rear wheel bias to put in? I'm going to have Level10 work it over before it goes in regardless, but I'm wondering which auto would be best? USDM? EuroSpec? VTD(?) ?
What differences could I expect? Do other members feel it's worth it?
Thanks,
Jonathan
Good people sleep peacefully in their beds at night, only because rough men stand ready to do violence on their behalf.
Old 05-01-2005, 06:55 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thanks,
Jonathan
The Euro spec SVX trans is the same as the JDM - has the VTD awd system and 3.70 gears. While a swap to a VTD trans would be great (due to rear bias), there'll be a good deal of re-wiring to do. Huck369 just completed a 4.44 VTD trans swap into an SVX so I'm sure he could give more advice in this department.
The beauty of a switch to 3.90, 4.11 or 4.44 gears from a USDM Subaru, is the relative ease of the swap. It takes ~10-12 hrs and is a direct plug-n-play with your factory wiring.
The choice is yours. If money wasn't an option, I'd get a similar 4.44 VTD set-up like Huck just did + the valve body upgrade from Level 10.
-Chike
2006 Steel Gray WRX TR (sold)
Old 05-01-2005, 07:05 PM
-Chike
Thanks Chike,
I'm doing some engine work, and don't race, so don't feel I need play with the final drive ratio. (Likes to cruise at 80 MPH 3K RPM) What improvements / differences can I expect with the VTD?
Old 05-01-2005, 07:12 PM
Chiketkd's Avatar
Basically it'll handle more like a rear-wheel drive car. I'm sure it'll feel kinda similar to the adjusting the DCCD on a USDM STI to full rear bias (roughly a 33/66 torque split). While the awd still allows all four tires to pull you out of messy situations in rain/snow/ice, the rear bias will allow you to kick out the rear-end more easily in corners...
i.e. the 'fun' quotient increases exponentially!!!!
-Chike
Old 05-02-2005, 04:53 PM
oab_au oab_au is offline
Hi Jonathan,
Probable not cost effective to do. The trans can come from any Euro model SVX, the rear diff is needed, if you want to use the 3.7 that is in the front diff, otherwise change the front diff to your 3.54.
You will need the TCU from the same car, it will just plug in. The Japanese TCU has a speed limiter set to 115 MPH (it can be got around).
The AWD section is stronger that the US version, and don't seem to have as much trouble. The difference is noticed in cornering, the back wheels push the car forwards and the front wheels, only have to change direction.
One Arm Bloke.
Tell it like it is!
Old 05-02-2005, 06:58 PM
I don't believe the JDM tanny I used was a VTD, it was out of a 94 Turbo Legacy(which was probably before the VTD came out), had a EJ20T with a water to air intercooler (Closed deck block)
It was a direct bolt in (other than using the SVX torque convertor, and swapping the ring and pinion in the rear diff.
But I guess it would have had the more biased rear split...
Old 05-02-2005, 07:11 PM
Chiketkd's Avatar
Is that '95 still for sale Huck?
If I was in the market for another SVX that'd be the one to get. Those 4.44 gears from a JDM turbo Legacy must be killer!!!!
-Chike
Old 05-02-2005, 07:16 PM
I don't think it was Huck, the back of the VTD box is bigger and longer than the Transfer box. The drive shaft is shorter. The VTD box first came out in the 92 Euro SVXs.
One Arm Bloke.
Tell it like it is!
Old 05-02-2005, 07:19 PM
Question
What difference / improvement is the VTD over the 4EAT??
Jonathan
Old 05-02-2005, 08:31 PM
-Chike
Chike,
I've got a deposit on it right now, so I'm pretty sure it's sold....
And yes, those 4.44's make it a blast to drive, even if it is an automatic
Old 05-02-2005, 08:45 PM
Chiketkd's Avatar
Chike,
I couldn't afford to get it at this time anyway, I was just wondering though... Would be nice to have a 2nd one someday. I'll be adding a Leg 2.5GT, FXT or STI first though...
Wish people were selling SVXs with modded gears when I was in the market for my '96.
-Chike
