Old 06-22-2011, 08:09 PM
Re: any 5x114.3 8in wide fit?
I also like the clean look of the FOX RACING FX1 wheels. Available in diameters from 15" to 18"
Old 06-22-2011, 09:24 PM
Gamesy's Avatar
Gamesy Gamesy is offline
you can, but you'll have to be selective on tire size, there was a member who had 18x8
i'm running 17x7.5 and im' fine
Old 06-22-2011, 11:27 PM
XT6Wagon XT6Wagon is offline
These are 18X8 with 235/40R18 and have plenty of clearence all the way to the bumpstops. This is both wider and taller than stock in the tire. The rim IIRC is a +48 offset and looks like you could make it work with a 40 offset if you were conservative on tire selection as I tried a 8mm spacer in the front briefly. This is why the older mustang rims fit decent.
The current Mustang GT seems to have switched to a deeper offset so these rims should be even better. Just have to watch as they have some seriously wide versions.
Old 06-23-2011, 09:01 AM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
I really like those how much do those run?
XT6wagon: I was looking at some old svt cobra rims that were 17x8 do you think those would fit?
Jared
1992 dark teal SVX LS
Old 06-23-2011, 09:07 AM
they might, a previous poster said these fit and I've seen photos of SVX's with them.
http://cgi.ebay.com/ebaymotors/05-09...item19c50fe473
Old 06-23-2011, 10:41 AM
wawazat??'s Avatar
Yeah, I'm still around
If you do some searched you will find members have used a variety of wheel sizes (diameter and width) and tire sizes. I've used up to a 8.5" wide wheel (48mm offset) and could probably have fit a 9" wide version IF the offset were correct. An 8" wide wheel should fit wihout issues if the offset is between 40 and 50mm. You must also be cognizant of your tire size when combined with your wheel size. Tires will rub first. Tire size (width) with no fitment issues should be between 225mm and 245mm. With the correct offset wheels, 255mm width tires have been used with no issues.
Disclaimer-This is not a blanket statement of endoresement to any wheel/tire combo in the sizes above. You must choose what you are comfortable with and if they don't fit it is on you to make it work or deal with the issues. You may have to trial fit some wheels if you are concerned.
I've used wheels and tires on my SVX from 15"x7" (NOT a typo) to 17"x8.5" with tire sizes from 205mm to 245mm wide on the street to autoX courses with no fitment issues.
Down to none
Old 06-23-2011, 11:05 AM
I've used wheels and tires on my SVX from 15'x7" (NOT a typo) to 17"x8.5" with tire sizes from 205mm to 245mm wide on the street to autoX courses with no fitment issues.
nice disclaimer!
so it seems that i will have to do a trail and error type deal
thanks everyone!
Jared
Jared
Old 06-23-2011, 11:44 AM
92 SVX 92 SVX is offline
Not a typo? Wow how the heck did you get a 15 foot tall rim on there?
Old 06-23-2011, 03:42 PM
custom wheel spacers. Given tractor rims have a bolt pattern nearly the size of the stock rims outer diamiter.
Old 06-24-2011, 02:16 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
More Mustang wheels, Dayles car I believe.
Gene
Gene and Ben
Old 06-24-2011, 03:21 PM
wawazat??'s Avatar
dang
Down to none
