Old 02-12-2003, 03:24 PM
YellowBird's Avatar
YellowBird YellowBird is offline
Ya can't fix stupid
Pulling and vibration
Just picked up a '92 Silver with 116,000 miles.
Strong engine and strong on shifting. But.....there is a horrid pull to the right at about 45 mph, followed by a vibration.
I intend on having my Suby mechanic look at it next week, just thought I could get some ideas on what he should look for.
My Legacy Turbo quit on me a few weeks ago. He guessed it was the timing belt. It was....only to find out the ADJUSTER TOOL was still attached to the belt from the last change out. I've been driving it almost a year now.
Luckily it didn't do anything to the motor and I got away for under $225.00
Looking forward to getting the new SVX fixed and on the road. Boy oh boy do I miss not driving one.
Thanks!
1996 SVX LSi Yellow/White fade custom paint.
1992 SVX LSL Pearl
1992 SVX LSi Ebony
1992 SVX LSL Silver - parts
Old 02-12-2003, 03:42 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Take a good look at the tires. You may have a tire beginning to separate and cause the pull and/or vibration. It may also be more than one tire.
Old 02-12-2003, 03:48 PM
wawazat??'s Avatar
Yeah, I'm still around
Whoa
I took that post title WAY wrong!
Todd
Down to none
Old 02-12-2003, 04:01 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
I saw the post title, then, I saw that the last post was written by Todd. Then, my immediate thought was, "Well, that thread's gone to hell." I WAS RIGHT!
Randy Johnson
Mike Davis -- at Reading VI
Old 02-12-2003, 04:03 PM
wawazat??'s Avatar
Hey if Ron's not around
somebodys got to do it!
Todd
Down to none
Old 02-12-2003, 05:33 PM
Beav's Avatar
Not as old as Randy
And yet Todd's wife thinks I have a one track mind... sheesh.
Old 02-12-2003, 09:27 PM
Invisible avatar
Cool Re: Hey if Ron's not around
Todd
Hey, hey, guys - Why is it everytime the subject gets just a bit out of the box, I'm the prime suspect for taking things down to the next level? As a member of refined culture & impeccable tastes I object to the constant besmirching of my reputation. Should this line of innuendo continue, I shall be forced to pull up my pants & leave the party.
So there.
Ron (maddenly vibrating).
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 02-13-2003, 04:31 AM
Shoot me! I'm a Ronette.
Hey Ron,
I'm with you on this.
I just dropped in to see if the vibration was electrical or what, sho' enuff these guys are desmitching your reppitation.
Someday, at the mileage, you may have loose track rod ends or loose ball joint, possibly on the right side. Get the tracking checked, 4wheel laser.
Also, you may have a bent rim on the inside of the right wheel, check it while up and under.
Oommigosh, what have I said??
Old 02-13-2003, 05:25 AM
svx_commuter's Avatar
Re: Re: Hey if Ron's not around
Yeah Ron usually it's about getting into the box or staying in the box or looking for the box or making jokes about the box or wanting a box or finding a box.
Old 02-13-2003, 09:24 AM
Aredubjay's Avatar
And SHE'S right!
Randy Johnson
Old 02-13-2003, 09:26 AM
Aredubjay's Avatar
Yep, good ol' Ron. The roar of a thunderbird and the calm of a ripple.
Randy Johnson
Old 02-13-2003, 09:37 AM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
After looking at the results of my issue, I may have an educated guess at the problem.
I found that a bad CV joint(or 2) on my right from Axle was actually cause both a vibration and minor pulling to the right.
But, RF bearings, RF drive axle CV's could cause your issue.
It makes sence that you check the free wheeling of the front right wheel compared to the left, But check the Tire balance first.
Do you feel the vibration in the steering wheel, or the whole car?
If feel the vibration in the steering wheel, then lower ball joint, strutt, and control arm ball joint could also be a factor, if any of these are bad, it will cause pulling.
The key is whether the steering wheel shakes.
proof: my FR drive axle had 2 bad CV's, the right front wheel did not spin nearly as freely as the left. With the drive axle removed, it was clearly bad(both CV's)
Note: I haven't taken apart the Axle yet, so I'm not even sure if the inner joint is a real CV type, but you get the idea.
PS. the vibration was there but a mechanic could not diagnos the issue until it became more extreme. A back CV joint or 2 does not always cause the steering wheel to shake.
PPS. Hope for a wheel balance issue.
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 02-13-2003, 10:11 AM
Invisible avatar
Wink Re: Re: Re: Hey if Ron's not around
Leave me out of this one. If you must talk boxes, contact our Canadian or UK brethern. It seems they devote every December 26th to the subject.
Ron (sparring, but not boxing)
'01 Miata SE - 79K
Old 02-14-2003, 02:56 AM
Box on Ron.
Yes we have that box too but also down this way there is a far more interesting box and or boxes which you Ron would surely appreciate i.e. a very interesting and delightful component indeed.
Sorry classified stuff and the low down, is not for down loading, from down under, as instructed down below my signature but if you PM me down here I could give you the fare dinkum down under oil -- dinkum, no sweat and piss easy ! Meantime I too will box on.
