Old 02-20-2010, 10:26 PM
Green1995SVX's Avatar
Bilstein struts for SVX?
I stumbled on these pics. Any thoughts?
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 02-20-2010, 10:47 PM
Re: Bilstein struts for SVX?
These are probably emptied OEM struts with Bilstein cartridges and... stickers
Old 02-20-2010, 10:54 PM
If it is not just stickers alone
Old 02-21-2010, 01:47 PM
Is this image helpful in identifying what is going on here? Were we aware of bilstein inserts being available?
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 02-21-2010, 02:53 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Mike, if you pull an insert out and give them the specs I'm sure there is a bilstein which fits. Whether or not they ever marketed one as fitting the SVX is another question.
Old 02-21-2010, 03:24 PM
Interesting. I see.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 02-21-2010, 04:29 PM
benebob's Avatar
Penske Racing shocks are another option for inserts. I would suspect that WRX front inserts would work or be easily adapted for the rears. only difference i could find was the top threaded portion but that would be easily adapted if making a batch. Extended and compressed lengths are the same. Rebound and dampening would be different but that can be customized based on oil and seals.
Old 03-05-2010, 06:43 AM
sicksubie's Avatar
Will the Penske or Bilstein inserts handle higher spring rates than the Koni's?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 03-05-2010, 08:24 AM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
The Bilstein inserts can be had in any valving you desire for any spring rate, but pretty much need to be set up by Bilstein or a qualified service center. Penskes can be revalved by the end user quite easily for any spring rate. 200 lbs to 2000 lbs...no problem.
Bob Légère
EG33 Impreza tweaks
Old 03-05-2010, 11:27 AM
SuberNatural SuberNatural is offline
Do we have any part numbers from either of them for this?
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
Old 03-05-2010, 01:37 PM
benebob's Avatar
What Bob said on spring rates. No there aren't any part numbers I know of for either but both companies "should in theory be able to make them if they have all the info they need as I already stated. Penske is somewhat local and a whole lot easier to deal with as they speak the same language as we do. Granted they would probably cost more but for a true custom race proven suspension you can't go wrong with 'em. Just be prepared to pay for what you get.
Old 03-05-2010, 02:17 PM
Hmm i just picked up 4 complete struts to swap in this summer, maybe i will have to do some calling in the next month or so.
Old 03-06-2010, 12:34 PM
NeedForSpeed NeedForSpeed is offline
Buy those now .
Bilsteins were available in Japan for the SVX. I have a picture of a JDM car with a Bilstein decal on the front bumper
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 03-06-2010, 04:20 PM
Over the years there have been a number of Liberty/Legacy models sold in Aust that come with the Bilstein units.
