ABS codes with 5spd
has anyone had issues with the ABS giving off weird codes after converting their svx to a 5 spd??
you may have damaged the sensor. I let the hub fall to far and pulled on the sensor wire. then sure enough busted abs. check the how to section for diag.
I cant find specifically what ur talking about the abs section is empty and I can't find one labeled diagnostics... or did you mean diagram?
nevermind i found it
