Old 11-27-2017, 11:39 AM
DallasSVX92's Avatar
DallasSVX92 DallasSVX92 is offline
Fuel pump relay
Does anyone have a picture of the exact location of the fuel pump relay? Ive seen diagrams that point to the relay but Id prefer an actual picture of it. Im gettng spark but no fuel and trying to figure out why.
1992 SVX LS
2002 Park Avenue
2008 328i convertible
1993 GMC C1500 W/T
Old 11-27-2017, 12:30 PM
Re: Fuel pump relay
A little update, found the relay and got a new one from NAPA. Just put the new relay in and nothing changed. So now Im thinking fuel pump modulator or resistor. How can I find out if they are working correctly? And if not where do I get new ones?
1992 SVX LS
2002 Park Avenue
1993 GMC C1500 W/T
Old 11-27-2017, 02:58 PM
Re: Fuel pump relay
The resistor and modular are under the rear deck. The wires to the pump are under the rear seat, rhs. There should be 12V, to the pump for 5 seconds when the key is turned on, and 12V when starter is working.
Old 11-27-2017, 03:12 PM
Re: Fuel pump relay
This is the wiring for the pump.
Old 11-28-2017, 06:10 PM
Re: Fuel pump relay
Im really thinking its the resistor, its hot to the touch after ive tried starting the car. Ill have to get a new voltage meter as I cant seem to find mine any where.
1992 SVX LS
2002 Park Avenue
1993 GMC C1500 W/T
Old 11-28-2017, 08:21 PM
Re: Fuel pump relay
Unplug the resistor and put a jumper across the plug, the pump should run full.
Old 11-29-2017, 07:44 PM
Re: Fuel pump relay
What exactly do you mean?
1992 SVX LS
2002 Park Avenue
1993 GMC C1500 W/T
Old 12-02-2017, 12:14 PM
Re: Fuel pump relay
Another update, I unplugged what seems to be the fuel pump modular and now it starts right up and runs. Question is what to do now? I would think its not a good idea to be running the car with this unpluggged.
I tried to upload a picture but I must be doing somthing wrong because its not working. But when youre looking under the rear deck from the trunk, its the little grey box with a yellow sticker on it.
1992 SVX LS
2002 Park Avenue
1993 GMC C1500 W/T
Old 12-02-2017, 02:31 PM
Re: Fuel pump relay
The pump gets its ground through the modulator for full flow, or through the resistor for low flow.
It won't worry it to run like this, just won't run full throttle.
Old 12-02-2017, 02:52 PM
Re: Fuel pump relay
Ok good, thanks for the help! Im glad she finaly started after 2.5 years of sitting. Now onto the transmission issue...
1992 SVX LS
2002 Park Avenue
1993 GMC C1500 W/T
