Old 10-15-2009, 12:59 PM
Ownbot's Avatar
Ownbot Ownbot is offline
I'm the anti-do-gooder
Thermostat Replacment
So I believe that my thermostat is now stuck closed. Where exactly is it? I have heard that you have to get to it from underneath. I did a quick search and couldn't find anything on this subject. Thanks guys
Old 10-15-2009, 01:36 PM
Re: Thermostat Replacment
You have to get to it from underneath the car. The themostat is located at the front of the engine at the bottom, behind the housing that the lower radiator hose runs into.
Remove the belly pan and you will see where the thermostat cover (10160) connects to the lower radiator hose at the engine. Once you remove the two 10mm bolts that hold the cover, the thermostat (21200) and gasket (21236) can be removed.
You will need a bucket to catch the coolant and a 10mm socket. Be sure to let the engine cool down first and then remove the radiator cap.
Use an OEM thermostat and don't forget to get a new gasket as well. Both of these parts should be less than $15.00.
Put the old thermostat in a pan of water and bring it to a boil. Put a thermometer in the pan to see when it starts to open (if at all) If the water boils before the thermostat is fully open, it was bad.
Old 10-15-2009, 01:37 PM
ScottyB's Avatar
ScottyB ScottyB is offline
It's right inside this pipe...
97 Toyota 4Runner SR5, 5 spd
92 Ebony SVX AWD (4.44 gears)
Old 10-15-2009, 01:46 PM
Ownbot's Avatar
Thank you. Looks like a job for my friend with a lift. I don't crawl under cars anymore...lol
Old 10-15-2009, 04:43 PM
Green1995SVX's Avatar
You may be able to access it from above if you remove the radiator fan on the driver's side.
As others said, it's important to use OEM parts. The Autozone type have a high failure rate.
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 10-15-2009, 06:53 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Mike
I went through 2 autozone ones before the 3rd one finally worked. I learned to boil my thermostats to test them before installing
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
