maintenance problems
My back windshield defogger doesn't work and the light on the dash comes on and the metal strips tested ok with a test set about a year ago but it doesn't take the fog away. I was told to check the two connections on either side which I will do but are there any other suggestions out there? Also my remote control doesn't work any more and I was told to go to subaruparts.com and order another remote transmitter, is this the best parts store to go with?
afsquid green '92 100.5K |
The remote battery may be dead. Radio shack has replacement and you can search here to find it.
I don't know about the rear defroster. Do any of the wires clear off the fog? I assume inside fog. If you disconnect the leads to the window is there a resistance measurement to check for the wire grid? It may just be poor connections. |
The manual suggests using a small square of foil to wrap around one of your test leads, to test the wires. Place the foil wrapped lead on a wire, the other on the connctor to check for continuity. Perhaps, if you just unplug the defog terminal, and use a pencil eraser to clean it, then, reattach it, it may work again. Just a suggestion.
thanks
Do you mean the little batteries are GP27A in the module (there are about 7 or 8)? Some are corroded but also the wire inside the remote transmitter is unconnected. I wondered if someone could take a digital picture and email it to me to see where this wire would be soldered back to.
I will first check the connections on the rear defogger and then do what you suggested with the pencil eraser. The strips on the window tested with a test set and the light comes on up on the dash. Also, the security light does come on and blink on the dash but I don't have it on now since I have to maually lock my SVX and don't want the alarm to sound every time I unlock it. That's cool you and your significant other have SVX's. Are you going to Reading? afsquid '92 green 101K |
The GP27A battery is one small battery, shaped like normal AA/AAA. It replaces the 7 or 8 button-type batteries that originally came inthe remote. They are much cheaper too, about 2.00 for a pack of 2.
Check here for photos of how thw wire inside the remote is connected. Look in the "old/new alarm remotes" folder http://www.subaru-svx.net/photos/user.php?SVXtypeR|1572 The wite is connected to the metal strip that fits in a slot in the top of the remote. The pin that has the keyring attached to it presses snugly against this strip, making contact. You should be able to see the solder joint where each end of the wire was attached. Here is the thread that talks about it http://www.subaru-svx.net/forum/show...ghlight=remote That should fix it. And then there is the remote "chin trick", but that's another issue
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 02-14-2003 at 09:06 AM. |
My friends keep asking me why I walk around with all of that tin foil on my head and chin. They just don't understand about my remote for my SVX!
Earl,
I don't need the tin foil. They don't call me "Chrome Dome" for nothing. I can use my remote works from 3 blocks away, using the forehead technique.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
