Old 07-07-2006, 07:18 PM
dwd1985 dwd1985 is offline
1994 Honda Civic
A friend of mine has a 94 Honda Civic EX coupe., with a 4 cylinder engine. I have been enlisted to help fix it. It has always ran well (its a Honda Civic, they always last forever) but as of last night, all of a sudden, the weirdest thing wil happen. When you try and start it, it will start for about half a second and then turn itself off. Normally, when an engine wont turn over, it either just relay clicks, and wont being to crank, or it will crank without catching. However, this engine catches and starts, but will not continue to run. It doenst stall out either, it just turns off. What could this be? I pulled the spark plug wires, and it looks like the spark plug need replacing, and I disconnected the battery, but now it starts allright. If this should happen again, where should I look? Everything else looks ok, nothing is cracked, disconnected or broken. Also, does the civic ECU "learn" like our SVX ones do? Because now its idling pretty high, and I told her it would re-learn what sped to idle at.
Old 07-07-2006, 07:30 PM
NapaBavarian's Avatar
Good morning!
The solution will take several large guys, but should go fairly easy. You will need to start by opening the drivers door.
Once the door is open remove drivers hands from the stering wheel, some times previous installer over torques the attachments, so be prepared to to use a breaker bar if the driver is really attached.
Next, with one guy in the back seat and one in the passanger seat remove driver from car, carefully transport to waiting impreza and reinstall. Be sure to use loctite and you may need to temporarily tape the hands in place due to upgrade resistance.
Have a nice day
.Karl.
Old 07-07-2006, 08:22 PM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
How many miles are on it?
I'd start with the cheap solutions and go from there. Plugs and wires are a good start, then I'd replace the fuel filter and gas cap. If the car only runs for a second or so after startup, it's probably either fuel or spark.
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
Old 07-07-2006, 08:36 PM
Have a nice day
LMFAO!!!!
She actually wants to replace it with a Dodge Durango, and is saving up for that very trade as we speak.
Old 07-07-2006, 11:07 PM
It's Just Eric's Avatar
Missing in action
Good.TheCivicIsGarbage.IDontKnowHowThe****TheyGot
SuchAReputationForBeing"Reliable"
EveryOneISeeisEitherBrokenOrHas"Cool"Stuff3MDouble SidedTapedToIt
MySisterSpentLike5kInMatinenceForThe6YearsSheHadIt ....AndDamnedIfIKnowHowToFixIt.
IMeanComeOn...TheyDidntEvenPutTheMotorInTheRightDi rection...
R.I.P Cool Signature.
Old 07-08-2006, 02:27 AM
Speedklix's Avatar
Locker Link Solution
may sound crazy... but, check the coolant.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 07-08-2006, 08:38 PM
thundering02's Avatar
thundering02 thundering02 is offline
Giong back to the beaters...
Never answered the milage question either....Hondas are notorious for a timing belt every 100k miles.....but otherwise was beautifully reliable while I had it.
86 GMC Jimmy Blue and Silver- R.I.P.
87 Integra RS ~228k miles R.I.P.
92 SVX LS-L Perly ~186k R.I.P.
89 240sx se red ~165k miles Gone and unknown
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
85 BMW 325e ~ Gone and unknown
85 Ford Mustang getting engine swap now!
05 Colorado ~108k Daily Driver
Old 07-09-2006, 12:41 AM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Sounds like very weak fuel pressure. Either fuel filter, fuel pump, or the regulator is controled by It's just Eric's keyboard.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 07-09-2006, 06:14 PM
Royal Tiger's Avatar
Certified Porschephile
Come on Eric, you can get a used keyboard for $5 if you have a used PC store near you.
