front brake rotors
any recommendations for replacement front rotors
don't need drilled and slotted |
Re: front brake rotors
When I replace mine I will either go with Centric Cryo treated rotors or r1concepts cross drilled. Cryo treatment and cross drilling will help to avoid "warping" down the road as will switching to carbon-metallic composite pads. It isn't about racing as much as it is about avoiding "warped" rotors.
cryo treating rotors doesn't keep them from warping.
drilled and slotted are best for dissipating generated heat.
i have a set on my XT6, and will get a set for my Next Subaru. |
See article HERE I am using the Raceconcepts dimples/ slotted rotors and Akebono Pro_ACT full ceramic pads all around. .
Here is a link I found on cryo treating:
http://www.cdpautomachine.com/ecatalog/cryo.html It claims that surface uniformity is improved, which should help spread out the heat. It also claims that thermal conductivity is better. Finally, it claims that cracking from residual stress is reduced as is wear. So maybe a rotor that is cry treated before cross drilling is the best bet. You get the benefits of cross drilling, avoid the cracking issues, get better thermal properties, get a more uniform surface and get more miles before the rotors get too thin, which also leads to localized overheating.
