Screen in original 92 atf cooler
Does anyone have a picture of where the screen in inlet to the orginal atf cooler in radiator is located ?
Or if someone could tell me how to check it. I have a 92 svx, but im not sure if its the original radiator in the car. Planning of removing the screen if possible. Need to put in a extra cooler too. And i need to put in a external filter for the atf, also concider to put filter on both outlet and inlet line to the tranny, to catch any sludge from the atf coolers or lines, does anyone know if 2 external fliters would slow down the flow of atf too much ? |
Re: Screen in original 92 atf cooler
The Bronze mesh is right through the cooling pipe that runs through the bottom of the rad. It is not ment to be a filter, it is used to increase the cooling effect of the oil flowing through the pipe. It can't be removed. You should reverse flush the cooler pipe to remove any debri in there, then fit a ATF filter to the inlet side to prevent it from getting blocked again. As you live in a cold climate, you should fit the external cooler after the filter, before the radiator cooler, to ensure that the ATF comes up to operating temp, or the torque converter clutch won't lock up. Two filters would be to much restriction. You must ensure that the filter is for Automatic ATF operation as an engine oil filter is much finer and used with much higher pressures, and would restrict the cooling flow too much. This oil flow is at a very low presure and is pumped back to the box to lube the shafts and gears. All the best with your SVX. Harvey.
There is a series of phootos in Shotsky's album (over at yahoo) showing the stock ATF cooler with mesh filter and cutaways to show the inside.
http://pg.photos.yahoo.com/ph/shotsk...sky1/my_photos
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-04-2004 at 07:19 AM. |
I didn't see the mesh in any of those pictures but I guess it would show in a close up.
That cooler has a bend in the inlet and oulet pipes. The newer cooler does not. I looks like the inlet and outlet pies came out of the bottom of the radiator and not the side as on the newer one. The inlet and outlet point straight out on the newer one. The cooler looks about half the size of the newer one.
Thanks for the information guys.
Will check mine closer. Johannes |
