Tranny fluid supply lines
Finally got around to installing my permacool tranny filter, and in the process, ran into a small problem. The instructions say, quote, "Locate the transmission fluid lines. They can be found running from the transmission to the bottom or the side of the radiator. Determine which is the supply line (pressure hose) by starting the engine and feeling both transmission fluid lines. The warmer line is the supply line." Well while under the car, looking forward towards the bumper, there are 3 lines going into the radiator. I really did not feel like sitting under the car with the engine on, and I tired letting it run, and then jacking it up again, but felt no significant difference in temperature. So can someone who has put on their own filter let me know which hose they figured it out to be? Looking forward towards the bumper, is it the drivers side, the center hose, or the passenger side?
Well, I would bet my pennies to your dollars that you didn't look in the How-To Documents for the answer or you would have found it.
Look at this picture for your answer. The fluid goes from the transmission into the passenger side of the radiator and back out of the drivers side which goes to an external filter, or back to the transmission. Good luck.
Yes, I did look in the how-to's, I always do before attempting to fix something or install something on my SVX. I saw that picture, but until now, did not realize that it was looking down on the path, and not from the side. It hit me all of a sudden as I was looking at it, when I noticed the radiator cap on the pic. That makes sense to me now. Thanks.
With the air cooled unit last, it can cool the ATF lower than 80C/176F. The trans then will unlock the converter, to allow the torque converter to operate, to raise the temperature to the desired 80C/176F. If on a cold day, it cools down to 10C/50F, it will change back to 3rd. So fuel consumption will increase. Harvey.
I used that picture so that it would show the flow. That is one choice of doing the cooler and the others are shown in the How-Tos as well. It shows in series, parallel, and a cople of others.
