5 MT AutoXers
Seeking advice from 5MT owners who autocross. Am now familiar with the general understeer and forgiving nature of the 4EAT car on the track. Even though track turns aren't as tight as AutoX, there should be similarities, especially when you get into the turn too hot. The 4EAT tends to start plowing with maybe a little terminal tail switch. Getting on the gas and turning more tightly causes the car to drift out, without either end getting loose. On the 5MT, how does the 50/50 torque split and the more direct engine connection affect the SVX's handling? Tips in advance of my first 5MT track day would be appreciated. Thanks
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
I never was able to fully kick out the rear end of my 5MT except one time when I whacked the brakes mid-corner. I imagine your car will still understeer as it did with the 4eat.
I noticed the same thing. Sometimes it feels like the rear is going to walk around on you but it never ever does. You have to pull some Tiff N./Jeremy C. maneuvers to get the back end to kick out
GreenMarine has some experience with this though.
The front end always plowed on my ebony. Really I always wished the back end would have more decision making power in the corners. I attended my 1st auto-X in the 6mt the sunday after reading and all I have say is WOW. What a difference. The ability to kick the back end where u want it keeps the front end from plowing. If you are seriously trying to get rid of this kind of manuvering difficulty, there is a center differential available for 5mt boxes that will convert it from the 50/50 split to 35/65 like the 6mt's. They are fairly pricey and can be found at www.Rallispec.com. I am sure there are other sources but this is one I know of for sure.
Edit: Just took a look at the price again and at $1438.00 for the Cusco Tarmac center diff. I don't blame you for reconsidering. Might as well pick up a 6mt for that price Tom Last edited by TomsSVX; 04-28-2006 at 10:44 PM. |
On the track with higher speed turns, kicking the rear end out is not so important. Predictability is what is really important. Don't want any surprises. A balanced drift that gets predictably wider with more throttle is more important. The plowing mainly occurs on the 4EAT if you enter the turn too hot and are turning hard while braking hard. I was wondering what the torque split change might do to that balanced drift.
Like I said. It seemed to be much more controllable. When the front end of my car used to plow the corner or just feel front heavy, the rear bias seemed to balance it out and allow the entire car to just glide wherever I wanted it to. Only real problem I was having was figuring out where the course was, it was pretty diff. course
Tom |
