Sti 08 rear brakes to svx ???
How Impreza sti 08 rear brakes differ from svx rear brakes? Are there any possibilities to install rear sti discs and calibers to svx rears? Those are 114.3.
svx my94 vtd EUDM -custom Spax coilovers Last edited by Chris_; 11-16-2012 at 01:40 PM. |
Re: Sti 08 rear brakes to svx ???
i bought some 06 sti rears planning on doing this conversion, these can be made to fit very easily, you just need to press out the drive flanges fro myour svx hubs and the sti rear hubs, un bolt both backing plates, put the sti backing plates on the svx hubs, then re assemble and bleed brakes etc.
Any update of this? Does someone have more information about this or how-to-do document somewhere?
svx my94 vtd EUDM -custom Spax coilovers |
I've done this to my svx, it really is just a case of simply buying backing plates, rotors and calipers for an sti and fitting them up and you have sti rear calipers that go nicely with my brembo 6 pot front caliper kit, see the link below; http://www.subaru-svx.net/forum/showthread.php?t=60338 but as far as a how to do document it would be this; 1. remove hub from car 2. separate dive shaft from drive flange 3. press out drive flange 4. disassemble handbrake assembly 5. remove four bolts attaching backing plate to hub 6. install new sti backing plate 7. install handbrake assembly 8. press in drive flange 9. install hub to car 10. fit new sti rotor DBA part number dba4655-10 11. fit new sti brembo caliper and bleed thats just off the top of my head but i don't think i missed anything i was thinking of using the complete hub assembly off an sti but the strut mount sits forward of the the svx hub which would move the angle of the of the strut and i'm not sure how this would affect suspension geometry
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive Last edited by 'E'; 03-30-2013 at 06:03 AM. Reason: Additional information |
I just bought 2pot sti brembo calipers to rear from 04 sti (these was test fitted to -06 5x114.3 brakes and fit). I thought every 5x114.3 sti rear brembos were same but now when I am buying discs I was told that -06 and -08-> discs are different. What discs I should now buy or are my calipers even wrong to fit to svx?
The rotors from 05-07 are the right fit, 08 on rotors are the same except for hat height (front rotors are still the same) 05-07 hat height is 67.5 where as 08 on hat height is 63.5 a four mm difference
DBA sell multi fit rotors to suit 02-07 part number dba4655-10 the 10 means 10 holes 5x100 and 5x114.3 08 on part number is dba42656-1 (not the one you want) Hope that helps
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive |
