Old 04-01-2007, 07:07 PM
not enough movement in the springs
Old 04-02-2007, 06:08 AM
rallyingrob's Avatar
rallyingrob rallyingrob is offline
LOL
agreed tom !!
konis are like eggs
pretty strong.......
but cant take a pounding....
(sorta like rally neons!!)
neons make decent solo/race cars.......but in rallying they tend to come apart...starting with bent rear lower control arms ........
ps.thanks matt !!!
now i have an idea of where to start at least.i was in the dark on spring rates....
i'm too svxy for my car
rob
92 ebony 4.44's rock !!
Old 04-09-2007, 08:59 PM
mbtoloczko's Avatar
sans SVX
Originally Posted by TE1221
Why is Koni/GC bad for rallying? too stiff? Or the fact that they don't warranty racing application?
Less travel than stock. Cannot take the abuse.
Mychailo
Visit my locker
Old 04-10-2007, 02:21 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
in that case... would the koni/gc setup be a bad choice if the area I paticularly drive in (new brunswick rutgers university area) because its full of potholes, raised roads and rough roads.
can it stand up to the punishment?
I need to replace my struts again because the new ''old'' struts couldn't take the daily road conditions
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 04-10-2007, 02:30 PM
they should handle the conditions just fine... its all how you have the konis adjusted... I would leave the rears a full turn off of full firm and leave the fronts 1.5 turns of full firm... This will allow the springs to react more and take load off the struts on rebound.
