Old 10-22-2007, 06:23 AM
Tobi Tobi is offline
Send a message via ICQ to Tobi
No its OBD-I, i have this Connector.
http://www.graphics.cornell.edu/~v/b.../connector.jpg
After work i try the RS232 Hex Comm Tool.
"You need to set the tool to the correct baud rate and protocol, then send a hex command something like 78 12 34 00 to query the memory at location 1234. The response should be 3 bytes repeated over and over 1234xx1234xx where xx is the contents of the memory at address 1234.
send 12 00 00 00 to stop it."
Is this proceeding correct?
Old 10-22-2007, 06:54 AM
Nomake Wan's Avatar
Retired
Yes, that's correct. Basically:
Open Hex Comm Tool
Press F1 Key
Select Correct COM port
Set to Baud Rate: 1954, Data Rate: 8 bit, Stop Bit: 1, Parity: Even
Click "Open" to activate COM port.
Type "78123400" into the text box and press enter key.
You should get 123400 repeated over and over until you type "12000000" into the text box and press the enter key.
Old 10-22-2007, 09:29 AM
what if using different connectors you CP won't pick up a rom ID?? I have used 3 different connectors with 2 different computers on 2 different 92 models... WTF if wrong with my stuff??
BTW Upnorth is working with me to try and find a solution if anyone is interested
Old 10-22-2007, 09:51 AM
Nomake Wan's Avatar
Retired
I'll get in touch and see if I can't walk you through it too.
Old 10-22-2007, 11:14 AM
So I am back with some news.
I sent the hexcode and my ecu answer with this.
TX>78123400<TX
0042000000
I am sure that the code came from the ecu because when i unplugged
the Select-Monitor-Connector then i got nothing back.
Is my ECU a special one?
I can change this settings for the Converter.
http://img141.imageshack.us/img141/7...ngscom3uk3.jpg
Are the parameters correct?
This parameters are the defaults.
I test some values but without a success.
Old 10-22-2007, 12:24 PM
YES it works
This is the correct wiring:
GND(black)(USB-cable) to GND (green/black)(SSM-connector)
TXD(orange)(USB-cable) to RXD (blue/white)(SSM-connector)
RXD(yellow)(USB-cable) to TXD (orange/white)(SSM-connector)
Green Light for this Adapter
http://apple.clickandbuild.com/cnb/s...dCategoryID=47
Thx 4 help @all
Old 10-22-2007, 11:17 PM
Nomake Wan's Avatar
Retired
Hahaha, the transmit/receive wiring was just backwards? I love simple fixes.
I'll have to check out that adapter, it looks really promising.
Old 10-23-2007, 02:49 AM
Yes that was the problem
The Adapter is absolutely advisable.
If you know the wiring you can build it in few minutes.
In the next days i will check the adapter thoroughly.
Tobi
Old 10-23-2007, 02:54 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Thumbs up
That's fantastic news Tobi, thanks for the information. This looks much easier than building electronic circuits.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 10-23-2007, 03:02 AM
Nomake Wan's Avatar
Retired
Agreed. I will actually have to see about getting my hands on one of these and seeing if it is or is not succeptable to the "92 Error." Somehow with it being self-powered and all I can't imagine this being the case.
Old 10-23-2007, 03:04 AM
b3lha's Avatar
Phil & Belha
ROM number decoding
Here's a bit of trivia.
Mike sent me a dump of his ECU rom to add to my collection. I've noticed there may be a pattern to the version numbers:
722515 - 92 JDM SVX
722525 - 92 USDM SVX
742512 - 94 JDM SVX
742521 - 94 USDM SVX
7432A1 - 96 UK Legacy
744014 - 95 JDM WRX
All the Subaru JECS ROMs seem to start with 7
I wonder if the digit in position 2 indicates the model year 2=1992,4=1994 or the year the code was last revised.
Maybe 25 means SVX or EG33
Maybe the digit in position 5 is the market 1=JDM, 2=USDM
Maybe the digit in position 6 is the revision level of the code
Just speculation and not really useful information.
Old 10-23-2007, 04:27 AM
722515 - 92 JDM SVX
742512 - 94 JDM SVX
744014 - 95 JDM WRX
That is very interesting speculation Phil, and I can't agree that it is not useful. The most interesting repeat observation is the apparent country code for the software.
JDM appears to be #1 each second last digit
USDM is #2 for each second last digit.
The second digit could well mean year of manufacture, but it would be nice to see 1 in this position to confirm the suspicion, because a lot of the 92s were built in '91.
As regards being useful it will mean we can identify an ECU bought from a scrapper and ensure it will work correctly when used as a donor.
Old 10-23-2007, 07:14 AM
Nomake Wan's Avatar
Retired
You'll have to take your contraption to a UK SVX meet, find an actual UK SVX, and dump its ECU. I'd be willing to wager that the character in position 5 will be 'A'. SVXistentialist is on to something with the country code.
EDIT: Just bought a Metra adapter and the USB-TTL adapter for $40 total... I'll assemble it as soon as I get it and run some tests.
Old 10-25-2007, 04:20 PM
ok... think mike and I found the problem. Seems my serial cable might as well be a cereal cable.... gotta get a new one cuz its the missing link right now.
Old 10-26-2007, 03:08 PM
b3lha's Avatar
Phil & Belha
Assuming both ends are 9-pin D type, you just need to connect pins 2,3 and 5 at each end. Connect it straight through, 2 to 2, 3 to 3 and 5 to 5. Ordinary three-core household appliance flex works well, no need to spend over the top on fancy multicore shielded computer cable.
