Old 08-25-2011, 04:49 AM
Andrew P.'s Avatar
Andrew P. Andrew P. is offline
The Ebony ones are faster.
Just another HID question.
I'm getting ready to order a HID kit from DDM Tuning.
The 5000k low beam kit is what I'm after.
The question is, 35w or 55w?
Thanks.
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU.
77' IHC Scout SSII
Old 08-25-2011, 07:35 AM
92 SVX 92 SVX is offline
Re: Just another HID question.
how bright do you want them? 35w is usually plenty bright.
Old 08-25-2011, 08:01 AM
Stick with the 35W. That is what most of us use. Much less chance of frying our old wiring. 55W ballasts work harder for not a lot more increase in output. That means they don't last as long. Plis thee have been reports of unwanted glare associated with the 55W.
55W HID bulbs are more expensive locate to replace if needed and you cannot use a 35W bulb with a 55W ballast.
In newer cars with OEM HIDs, modern lenses and projectors designed for them and modern wiring, 55W would be okay. In our retrofit plug-and-play, 35W is more than fine.
You won't be disappointed.
Old 08-25-2011, 11:42 AM
I use the 35W and I have been very happy with them.
Old 08-25-2011, 06:01 PM
immortal_suby's Avatar
Thread Killah
I use 35w low beams and 55w high beams.
IMO, the 55w would be too bright for low beams.
Locker Link
2015 BRZ Limited 6MT
Old 08-25-2011, 07:49 PM
I have 6000K HID low beams . Street Glow 100 watt high beams and Ion Crystal 85 watt fogs, PIAA Xtreme White brake and back up lights .
Old 08-25-2011, 09:36 PM
Andrew P.'s Avatar
Thanks guys, 35W it is.
77' IHC Scout SSII
