Old 03-14-2009, 03:57 PM
stiguy's Avatar
stiguy stiguy is offline
what tire size?
i got some new rims they are 18-8s with a 48 offset. what tire size should i get? 225/40/18 or 335/40/18. or any othe suggestions
Old 03-14-2009, 04:27 PM
Re: what tire size?
Assuming you meant 235 and not 335.
Mathematically:
stock is 24.86" tall
the 225's are 25.09" tall
the 235's are 25.40" tall
If you don't mind going slower and risk rubbing depending on your offset go 235's. I would personally recommend the 225's unless you can find a 35 series. (235/35-18 = 24.48" or 245/35-18 = 24.75")
Old 03-14-2009, 04:48 PM
stiguy's Avatar
Re: what tire size?
yea 235 my bad
Old 03-14-2009, 05:37 PM
Re: what tire size?
225/40/18 would be my choice. I was going to say 235/35/18 is also close but they are very rare and over $200.00 per tire.
Old 03-14-2009, 07:32 PM
Re: what tire size?
Either is a good choice, 225 is what Subaru put on the 17x8 STi wheels. I have 245/40/17's on my BBS rims (17x8), and really like the size. The tire does "bulge" out from the wheel a tiny amount (only noticeable if you know it's there, otherwise they look very square), but this helps protect the rims. I nudged a couple curbs at toll stations and the extra tire width was enough to keep the rims clear.
Old 03-14-2009, 08:13 PM
Green1995SVX's Avatar
Re: what tire size?
I have 225 40 18's and they fit perfectly! I have noticed, though, that not all tires are created equally when it comes to fit. I have Continental Conti Sport Contact 2, and they are perfectly square. I noticed that Mike621 got Toyo Proxes 4 in the same size, and they're clearly stretched. We both have 18x8" wheels.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 03-14-2009, 08:56 PM
Re: what tire size?
This is due to the rim used to measure the tire's dimensions. There's no set standard for what width of wheel must be used to to measure the tire when it's installed, so it might vary by 1/2 or even 1" from one tire maker to another, giving inconsistent dimensioning.
Old 03-14-2009, 09:00 PM
Re: what tire size?
Oh. That's very interesting! I never knew that.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 03-15-2009, 02:21 PM
stiguy's Avatar
Re: what tire size?
awesome thanks. now i'll start looking for tires. i think some neo gen zr just got them for my volvo and really like them.
Old 03-15-2009, 02:23 PM
Re: what tire size?
I've had NeoGen 225/45/17 on my '06 Vibe for 2 years and they are excellent. You can even rotate them to all four corners for longer wear.
