Old 05-27-2008, 01:10 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
exhaust problem
my exhaust always sounds really raspy
especially when my pedal is pushed at that exact spot where im going 40 mph
i dont know much about what could be the problem and quite frankly idk where to even start to look to find/examine where the problem might be
any help would be appreciated
thanks
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 05-27-2008, 02:16 PM
It sounds like it might be the center resonator (right behind the main cat). This is a very common problem on our cars.
See part #2 in the diagram below.
Does it sound like a "buzzing" or a "can of bees" upon acceleration? It should probably be most annoying at around 2000-2500rpm.
It can easily be cut out and replaced with an aftermarket resonator from Magnaflow, etc. Some have just eliminated it all together and replaced it with a piece of 2.5" exhaust pipe
Old 05-27-2008, 04:16 PM
tiv0's Avatar
svxless
that sounds about right
its like that annoying sound where if you were to hear it without seeing the car that made it, you'd think "man, what a piece of crap"
ill definitely check it out
thanks
Trevor
Avondale, AZ
1987 BMW 325is
Old 05-28-2008, 11:38 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
you can cut it out and put a pipe there but some people have said the car makes a "fart" sound with it removed... yet to cut mine out... its doing the same thing
- John
Old 05-28-2008, 12:28 PM
I have replaced mine with the Aero Turbine AR25 2.5" stainless steel resonator. You can get it for about 57.00 from Aero Exhaust at http://www.aeroexhaust.com/import_resonator_ar25.html
svxfiles has used these resonators on many exhaust systems, including his own, as well as mine HERE
