Old 06-06-2008, 08:27 AM
They'll work fine....but it does have the hydralic clutch set-up which is a little more trouble to install than the cable set -up..
Old 06-06-2008, 08:41 AM
zukiru's Avatar
zukiru zukiru is offline
Winona is my yang.
Originally Posted by huck369 View Post
And you may have too, as I usually bring FrankenWedge AND my SVX to the meet...but with gas prices the way they are, I'll probably just bring FrankenWedge this year......
(I figure I'd be burnt at the stake if I didn't bring FrankenWedge...)
I would cry,.
Old 06-06-2008, 08:43 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Originally Posted by theallpowerful View Post
I have a line on some parts from a 98RS, provided I get everything, it should work?
I'm not sure about the RS, but most Imp's use a rear diff that is different than ours, so it can't be used to convert our LSD to their gear ratio.
The diff needs to have sideplates held on with 5 bolts. Many Imp's have screw in side plates, similar to the sideplates on the front diff.
Here is a chart that will help determine the final drive of whatever trans you find. If the donor has a screw in sideplate, just get the matching ratio from another car.
The SPDA - Transmission Chart
Old 06-06-2008, 11:08 AM
The RS uses the same housing as the SVX on the rear diff...I'm pretty sure only the EJ18 Impreza's have the smaller housing...
Old 06-06-2008, 11:18 AM
Hocrest's Avatar
Good to know
Old 06-07-2008, 08:39 AM
theallpowerful theallpowerful is offline
before I take this on, Im going to see if I can just get out of the car and move on to something else. Basically, im at the budget cap now, and swapping the trans would mean I have to sell that dollar amount out of the interior. Anyway, if it doesnt sell in a week or so the swap is ON!
sale link: http://www.subaru-svx.net/forum/show...019#post551019
