Old 02-17-2007, 05:09 PM
Roger8519 Roger8519 is offline
1500 RPM sound
Everytime that my car is around 1500 RPM it makes a sound llike something is vibrating or rattling, speed does not have an effect on the sound, it is only at that speciafic RPM. Anyone know what this could be, it is very annoying and makes the SVX sound like a piece of crap, which we all know is forbidden lol. PLEASE HELP!!!
Old 02-17-2007, 05:16 PM
Trevor's Avatar
Trevor Trevor is offline
It would appear that probably an exhaust heat shield, or a muffler baffle could be rattling. Listen under the car, while someone runs it at the critical RPM.
Trevor, New Zealand.
Old 02-17-2007, 10:00 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
its doing the same thing my car is... i traced mine back to the "primary mufler" or what looks to be a resinator
- John
Old 02-17-2007, 10:29 PM
Mr. Pockets's Avatar
Moderator
Yeah, I would suspect the resonator. I had mine replaced with a straight pipe. I'm not thrilled about the increased exhaust noise, but it is better than the buzzing.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 02-17-2007, 10:49 PM
The buzzing is a very comon problem and it drives most people nuts.
Old 02-18-2007, 04:49 PM
I had to weld the heat shield brackets on mine twice so far. if you could see thu the floor it would be right under your left foot.
Old 03-10-2007, 11:36 AM
Suby Fan's Avatar
would some one who likes rumbling exhaust be bothered by this noise?
- John
Old 03-10-2007, 02:03 PM
The rattling sound is more like a fizzle or something loose about to fall off the car so everybody hates it.
If you mean the change in exhaust note, it depends. I found same as Mr Pockets that I did not like it. The sound is not deeper or rumbling. Instead it gets harsher and flatter and louder without the resonator.
If you are good with a welder or brazing rods, cut out the resonator, replace with straight pipe and see if you like it. [don't throw away the resonator]
Personally I thought it was awful.
Old 02-18-2007, 05:32 PM
It's most likely the baffle plates in the resonator. It looks like a cat, but isn't.
[When it's rattling, it's actually a dog. ]
Replacement with a straight pipe works, but changes the sound for the worse, big time. A new resonator is expensive.
Best advice I can give is to cut out the resonator, and temporarily replace with straight pipe. Keep the resonator.
If you are happy with the new sound, then OK. If you don't like the sound, cut open the resonator around the circumference with a fine disc. There are baffles inside. They will be loose. Spot weld them. Weld back on the lid. Cut out the straight pipe and put back in the repaired resonator.
No more rattles.
Old 02-18-2007, 05:35 PM
It can be heat shields either. They are easy to see and repair.
If you fix them and there is still a rattle, particularly at the frequency you mention, it is the baffles in the resonator causing it.
joe
Old 02-18-2007, 06:10 PM
wannarace928's Avatar
wannarace928 wannarace928 is offline
Send a message via AIM to wannarace928 Send a message via Yahoo to wannarace928
Classic SVX
Mine was doing it due to a heat shield on the catalytic converter making noise and resonating in the resonator (EXTREMELY IRRITATING!! ). Eventually the bottom of the heat shield fell off (while my aunt whom I had just met and picked up from the airport was in the car, didnt give her a good first impression) and we put a metal band around the catalytic converter and other half of the heat shield to stop the rattle. It has worked for quite a while now.
Old 03-05-2007, 10:32 AM
2NI's Avatar
2NI 2NI is offline
Send a message via MSN to 2NI
I have it also... The rattle sound... Drives me crazy!!!
Beast from the East
Old 03-05-2007, 10:58 AM
Denis
see my post #7 above. It can be loose heat shields, which are external, and you will find the loose one by having somebody rev the car while it is up in the air on a ramp. This rattle is caused by sympathetic vibrations in the exhaust line.
If it is internal, it will be loose baffles inside the resonator. These are harder to spot on the ramp. They will be more noticeable when the car is moving than when it is stationary. [And more annoying! ]
If it is internal in the resonator, the advice in #7 will save you a lot of Euro.
