help the Weasel!
I could use some senior SVX owners advice.. who may have dealt with this issue..heres the situation: my SVX has a moderate oil leak..but im not sure what it is.. as in engine oil or power steering fluid.. I leave some spots everday or when the car sits for more than 15 min it will leave some fluid..I checked all fluid levels and can find no tell-tale signs of loss..the only suspect is the ps fluid..it smells burnt and looks awful so I siphoned as much out as possible and replaced with atf..I should do it all but havent had the motivation to yet..when I drive the SVX hard on the freeway with many downshifts and such or high susatined speed 80+ mph for any given time over say 15 minutes the car will start smoking from under the hood as soon as I come to a stop..its so bad it will appear my car is on fire..the source is somewhere behind my engine block near the front diff and ps unit..the smoke smells of oil..not coolant mind you..again all fluids are not showing loss..yet the car leaks..when I got under her the other day I found some fluid dripping from the assortment of metal lines near the ps unit and front diff..the fluid blows around a bit and makes it look like its from the oil pan which it isnt..I will poke around there this weekend ..but would like some advice first to maybe shorten my search sorry for the long read but I wanted to be as informative as possible..thanks guys & gals for any help!
I Have My Svx For About 3 Or 4 Years Can't Remenber. But I Started With The Same Simptoms. I Tought It Was The Ps Preasure Hose. I Replace It. But No, After I Couple Of Months The Trany Went Out. I Found This Web Site And Did Some Research. I Learn That The Major Problem With The 92-93 Models Is Heat. And After A While The Fron Diff. Seal Wears Out And With The Oil Preasure Inside The Trany You Will Start Having Oil Leaking. Mine Started With Just A Little Bit Every Once In A While Until, !!more And More And More!!!! I Did The Trany Oil Filter Change Add The Oil Cooler. But Too Late. I Hope Thi Will Help You. Please Let Me Kow If You Have More Questions.......
I dont want it to be the tranny its shifting fine and works as well as it should right now..and I got through changing the fluid out etc just recently..Im going to drive her more patiently and not promote this problem til I know what it is exactly
Sorry To Sound Negative, But That Is How Mine Not A Problem At All. With The Trany. You Said That It Leaves Oil On The Ground, With Your Finger Smell The Oil. It Smell Diferent Than The Motor Oil. And Then If It Smells Like Trasmission Oil. Start The Car And Then Turn The Steering Colum From Lef To Right Several Times. And If You See Smoke. You Are Lucky!!!!! That Means That You Ps Hose Is Leaking.... Remember That Oil Under Preasure Will Look A Way Out. That Is Whay There Are Seals. To Make Sure The Moving Part Sticking Out Will Be Need To Be Lubricated, But We Need To Keep Oil Inside......
How Far Are You From Vegas???
I have had this "on fire" thick smoking on both my SVX's. Both times I was lucky enough where it was the high pressure.side of the power steering lines. Of course, being that lucky costs about $300 each time at the Subaru Service Dept. But!! Mine did pressure clean everything and cleaned up the mess it made in the 2 months before I got it fixed.
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
