Old 06-21-2008, 07:10 PM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
WTF!?
You know the little hose that connects the 2 nipples on the top of the trans, mine was missing so i put one on, drove my car for a while and decided to check the fluid. car running, i pulled the dipstick and old faithful came out of the dip tube. i didn't overfill the fluid... wtf?
-Nate
'92 LS-L Pearlie
Old 06-22-2008, 05:53 AM
michael's Avatar
michael michael is offline
What Potholes ???
Re: WTF!?
Someone please correct me if I'm wrong but I believe those are vent holes. They are not supposed to be joined aka plugged. There are supposed to be 2 seperate squiggly hoses that route to either side of the trans.
Old 06-22-2008, 07:52 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: WTF!?
Yeah, two seperate vent tubes. How long were they connected? It's possibal that fluids have cross contaminated, it's probably best to drain and refill both the ATF and gear oil.
Old 06-22-2008, 01:22 PM
Sir. Nate's Avatar
SVXtreme
Re: WTF!?
the subaruparts.com diagram confused me, they were connected for 15 minutes, I used a clear tube and it didn't have any of either fluid in it when I threw it away. I'm going to be burning ATF off my engine for a week...
-Nate
'92 LS-L Pearlie
Old 06-22-2008, 02:15 PM
michael's Avatar
What Potholes ???
Re: WTF!?
Just because there is no fluid in the tube does not mean the two fluids have not mixed. With the fluid level as high as it was it may have spilled over. Trans fluid is not an adequate lubricant for the front diff. I'd change the fluids unless you want teeth in your pan.
Old 06-22-2008, 04:58 PM
oab_au oab_au is offline
Re: WTF!?
I don"t think. the two oils have mixed. I think with the two hoses connected there was no way for the pressure build up in the auto box to escape, so it pushed the ATF up the dip stick tube. No worries Nate.
One Arm Bloke.
Tell it like it is!
