Best Tranny Cooler
Searching turned up too many results so i figured i would ask this here. Going to install tranny cooler before my trip up to the mountains this weekend. Need a little better cooling because I always see the trans temp light just before i reach the top of berthoud pass. I have LAN's tcu so i figure it's hotter than i want but not cooked yet.
1. What kind and what size did you use? 2. Gauge? |
Re: Best Tranny Cooler
For reasons I have stated in the past (miminum flow resistance and avoiding excessive cooling for cold weather), I like the following options, found at summitracing.com:
Flex-a-lite 4109 Flex-a-lite 4110 Summitracing SUM-G4966 Even the 4109 should still have three times the cooling capacity of the internal cooler, if I recall correctly.
LAN's recommended setup, a cooler inside the front fender with a thermostatically controlled fan should be good also...
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
so looks like fin type in the wheel well is good. gota get it done by friday so ordered one from napa and will put it in tonight/tomorrow.
I sure hope you also will be installing a proper gauge as well.
cooler is a must, gauge also wanted. will probably have to order one as all the local shops stock gauges but not senders or kits to hook them up. anyone got a part number for a good gauge that works with stock sender or a kit that works well?
