Which side is "Bank 2" (knock sensor)?
The check engine light is on, and I'm getting a code for Knock Sensor (Bank 2). Is Bank 2 the driver's (left) side? That's my guess since, as I understand it, that side of the engine has the even number firing cylinders (2-4-6).
Re: Which side is "Bank 2" (knock sensor)?
In the USA, for the six cylinder H6 engine, Bank 1 is on the passenger side, Bank 2 is the driver’s side (left side as you sit in the car) If you are in front of your car, looking towards the windshield, then bank 2 is on your right. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 05-24-2019 at 08:49 PM. |
Thanks, John!
Recommendation: do them both.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss |
Are both sensors identical? (e.g.: interchangeable, same part number, etc.)
How do you disconnect the white electrical connectors at the far end of the sensor assembly? Do you squeeze those little wings together? Last edited by Brian; 05-23-2019 at 06:28 PM. |
I recently bought a couple, but haven't changed them yet, here's some thoughts on which brand:
http://www.subaru-svx.net/forum/showthread.php?t=64840 I was also searching for how-to-replace tips and found this thread: http://www.subaru-svx.net/forum/showthread.php?t=17952 I'm planning on doing the timing belt, water pump, etc., so I'll switch out the knock sensors when the belts are off doing the "remove the engine lift bracket with the compressor still attached" trick. Cheers, Ian. |
Edit: Y̶e̶s̶ ̶ No. There's a tiny push-down/in lever on the grey connector that plugs into it.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. Last edited by SVX_MY_BABY; 06-10-2019 at 08:20 AM. |
