More problems...
I'm moving this from my progress thread into an actual technical thread. Sorry for creating so many, but I think this is where this problem belongs.
I got the motor put back in and fired up. She turns on and runs pretty well BUT I am having a few problems. To start, there is NO CEL or stored ECU code when I try and pull them. When I first turned things on I got the 16 power light blinks. After some cursing I finally convinced the car to show me the code, and assuming I counted correctly it was a Trans code 22 which is listed as "Atmospheric Sensor." I have no clue wtf that is and I can't find it listed anywhere. Also, the car seems to be in limp mode. I can't get it over 3k or it initiates a fuel cut (at least I think this is what's happening). I can hear a relay tripping from the area of the ECU each time. Here's a video of said problem. I'm wondering if this could have anything to do with my delete of the EGR system. (I think I did this correctly) I plugged the exhaust port, plugged the port on the intake manifold, and jumped the two vacuum lines on top of each of the butterfly valves to each other. Then left all of the others alone. For Clarity about what I did... Here are the remaining vacuum lines that I just left. And here's the jump on top of the TB Someone mentioned to me that it could be related to a crank or cam angle sensor. I just recently replaced the cam angle sensor, but there are still the two sensors above the crank sprocket. For some reason my gut says this is related to the transmission error and not the motor so much, but I have no basis for that. After I pulled the trans code the car quit giving me the 16 power light blinks, but was still acting funny. I pulled the battery and did the procedure to reset things, and then the blinking power light came back. Also, basically every other time I try and start the car it doesn't want to start. It just cranks but doesn't catch. Much like when I don't have the ignitors plugged in. I pull the key out, put it back in and it fires up just fine When we were putting the engine back in we jacked the transmission up about as high as it would go. Could this have damaged anything? I think that's all of the information that I have right now. As usual, help is always appreciated.
ALICE: 2005 Forester XT (Ice Racing Machine) River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment) |
Re: More problems...
It does sound like crank/cam sensors. Can you locate some spares for testing?
I nabbed the two sensors above the crank sprocket from a junk yard car, but I have no clue if they work or not.
The cam sensor was just replaced recently so I doubt it'd be that. And that threw a code. Any ideas about this mysterious trans code? I want to address the confirmed problem first before taking shots in the dark.
Less than 3k rpms is definitely "limp home" mode. Try resetting the ECU first (using the 2 blue leads in the driver's side kick panel). Next thing would be to swap out the MAF for one you know is good. Third would be checking the IACV and TPS to make sure they didn't get "dinged" during the overall process.
Good luck! -Bill
The MAF was perfectly fine before I pulled the motor and it was just sitting on the counter since then. I do have another one that I will try swapping in to check. What is the IACV? Also, again, what about this Trans code? It's a known error right now, and can't be just looked over.
Okay, I watched your video and I "think" part of the problem may be that you're not supposed to actually start the car when you're checking for codes (yes, I counted the same 16 flashes as you did!).
Directions for checking the Codes 1) Remove the kick panel just beside the left foot rest on the driver's side. 2) Locate blue wires. 3) Locate black connector. Hold it notch up. 4) With ignition off, insert one of the wires into top row, 2nd pin from left. 5) Turn key to on position, but do not start the car. 6) Watch blinky check engine light on dashboard. Count blinks. Long blinks = 10, Short blinks = 1. 7) Keep watching blinky light until you get mesmorized. To clear codes (after problem has been resolved): 1) With engine off, stick the blue wires to 1st and 2nd pin in the top row counting from left on the black connector, with notch facing up. 2) Start car. Shut off car. Remove pins. 3) Read codes to make sure they are clear. No codes = steady blinks at 1/4 second intervals. CODE PROBABLE CAUSE 11 Crank Angle Sensor or Circuit 12 Starter Switch or Circuit 13 Cam Position Sensor or Circuit (TDC Sensor on Justy) 14 Fuel Injector No. 1 (Legacy, Impreza, Justy, SVX) 14 Fuel Injector No. 1 and 2 (XT, Loyale, GL, DL) 15 Fuel Injector No. 2 (Legacy, Impreza, Justy, SVX) 15 Fuel Injector No. 3 and 4 (Loyale, GL, DL) 15 Fuel Injector No. 5 and 6 (XT-6) 16 Fuel Injector No. 3 (Legacy, Impreza, Justy, SVX) 16 Fuel Injector No. 3 and 4 (XT) 17 Fuel Injector No. 4 (Legacy, Impreza, SVX) 17 Fuel injector No. 1 and 2 (XT-6) 18 Fuel Injector No. 5 (SVX) 19 Fuel Injector No. 6 (SVX) 21 Coolant Temperature Sensor or Circuit 22 Knock Sensor or Circuit (Right Side on SVX) 23 Air Flow Meter or Circuit (Exc. Justy) 23 Pressure Sensor (Justy) 24 Air Control Valve or Circuit (Exc. Justy) 24 Idle Speed Control Solenoid Valve (Justy) 25 Fuel injector No. 3 and 4 (XT-6) 26 Air Temperature Sensor (Justy) 28 Knock Sensor No. 2 (SVX, Left Side) 29 Crank Angle Sensor (SVX, No. 2) 31 Throttle Position Sensor or Circuit 32 Oxygen Sensor or Circuit (No. 1, Right Side, On SVX) 33 Vehicle Speed Sensor (VSS) or Circuit 34 EGR Solenoid or Circuit 35 Purge Control Solenoid or Circuit 36 Air Suction Solenoid Valve (Impreza) 36 Ignitor Circuit (Justy) 37 Oxygen Sensor (No. 2, Left Side, On SVX) 38 Engine Torque Control (SVX) 41 Air/Fuel Adaptive Control 42 Idle Switch or Circuit 43 Throttle Switch (Justy) 44 Wastegate Duty Solenoid (Turbo Models) 45 Pressure Sensor Duty Solenoid (Turbo Models) 45 Atmospheric Pressure Sensor or Circuit (Non- Turbo Models) 49 Airflow Sensor The transmission (TCU) has an entirely different self diagnosis process that involves actually pressing the manual button and moving the shift lever around... -Bill p.s. IACV = Idle Air Control Valve -- under the TB
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 03-24-2009 at 09:42 AM. |
LOL, The video was just to show the limp mode. I know how to pull codes. There are no ECU codes, and the trans code pulled was 22 after the whole PITA shift lever, press manual nonsense. The 16 Power blinks are just to say that there is a stored code.
Thank you for the responses so far, any help is always appreciated!
Well after some more fighting to get the code out of the car, I have double checked that the trans code is in fact 22 "atmospheric sensor." (as listed by the SVX-IW)
Code 22 doesn't show up on my AllData subscription so that's kind of strange. I have three good MAF's right now, and I cleaned/tried all 3 and the result was the same. I tried unplugging the Cam angle sensor and the car would only start for a second then stall. Unplugging either of the crank angle sensors resulted in a complete failure to turn over. Both also were accompanied by the correct CEL. How does one go about checking the IACV? I'll be testing the TPS sometime in the next couple of days, when some free time shows up. Thanks!
