Old 07-05-2007, 05:42 PM
wawazat??'s Avatar
Yeah, I'm still around
Finally
getting back to work on my five speed It's been toooo long since I last worked on it. Taking tomorrow off work and will keep pumping along on it. I have a question. I'm wiring the clutch safety and have selected the two wires from the harness. The switch on the pedal box has four terminals. Which two do I connect to?
Thanks,
Todd
Down to none
Old 07-05-2007, 07:13 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Thanks,
Todd
Wow, you may even have a working 5 speed before the racer does! Switch huh, just bypass it and remove it. You'll save nearly a half of a pound.
Old 07-05-2007, 08:14 PM
RSVX RSVX is offline
Network Design Administrator
Slacker.......
Life is a game. Play to win.
Old 07-06-2007, 08:31 AM
wawazat??'s Avatar
Thanks for the helpful replies Ben and Chris
Down to none
Old 07-06-2007, 08:36 AM
You want the switch that is closed when the clutch is pressed. Also, make sure you use a heavy enough wire, when I first wired the racer, I used speaker wire, when you tried to start it, the wire got hot but the car wouldn't start.... After I replaced it with 14g it started right up.
Can I drive it at the Anniversary meet after you get it finished?? Not sure where we'll be meeting for the 20th, but I'll see you there
Slacker
Old 07-08-2007, 07:20 PM
wawazat??'s Avatar
Real helpful group of SOB's around these parts
Back at it this week but all the pedals are solidly mounted now-WOO HOO!
Doug-If you are still around, I'm beating you
Todd
Down to none
Old 07-10-2007, 02:49 PM
Chad... if you have any questions, feel free to give me a buzz or a PM... I should be able to answer any questions you have... glad you are getting back at it
Old 07-10-2007, 02:50 PM
Oh, BTW the switch you want to use is the top one... or the all black one... the black and blue switch is for the cruise control only and you cannot use it. The brake switch is the same...
Old 07-10-2007, 09:25 PM
wawazat??'s Avatar
Thank YOU Tom .
I have been toying with the idea of retaining your services to finish it up for me...hmmm.
Todd
Down to none
Old 07-10-2007, 09:29 PM
sure... all it takes is a phone call...
tom
