headlight go out every month or so
well ever since i bought the car (last August) i have had to replace one of the headlights in the car about once a month. after several pairs of bulbs and many different combonations of makers i thought to ask you guys if you know what is going on. also only one of my fog lights is completly out and in not even getting power and one of my taillights only comes on when i press the brake. thanks if you know something that i don't
You have one of two things. One. Contacts are loose. Spray some electric contact cleaner and make sure your contacts are touching. Two. You have some electrical problem and I will have to think a little more.
L
Lwin M. Maung (Member # 147) Current SVX: NONE Previous SVXes: 1994 LE Barcelona Red 107k 1992 LS-L Pearl White 143k 1994 LSi Bordeaux Pearl 220k 1992 LS-L Ebony Pearl 184k 1992 LS-L Liquid Silver 145k 1992 LS-L Liquid Silver 102k 1992 LS-L Ebony Pearl 123k Other current cars:2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
What kind or brand of lights are you using? Some bulbs are not very good.
. Earl .... ... .... ><SVX(*> Subaru Ambassador [COLOR=silver]1992 Tri Color L[/COLOR] ~45K (06/91) #2430 1992 Dark Teal LS-L ~184K (05/91) #0739 1992 Claret LS-L ~196K (05/91) #0831 1992 Pearl LS-L ~103K (06/91) #1680 1992 Pearl LS-L ~151K (06/91) #2229 1992 Dark Teal LS ~150K (07/91) #3098 (parts car) 1992 White LS-L ~139K (08/92) #6913 1993 25th AE ~98K (02/93) #164 1993 25th AE ~58K (02/93) #176 1993 25th AE ~107K (02/93) #215 1993 25th AE ~162K (02/93) #223 1994 Laguna Blue Pearl LSi ~124K (1/94) #2408 1994 Laguna Blue Pearl LSi ~144K (10/93) #1484 1994 Laguna Blue Pearl LSi ~68K (10/93) #1525 1994 Barcelona Red LSi ~46K (02/94) #2624 1994 Pearl LSi ~41K (12/93) #1961 1995 Bordeaux Pearl LSi ~70K (02/95) #855 1996 Polo Green LSi ~95K (03/96) #872 1997 Bordeaux Pearl LSi ~55K (08/96) #097 2003 Brilliant Red LS1 Convertible ~29K (04/03) #8951 1999 Magnetic Red LS1 Coupe ~33K (04/99) #6420 My Email | Old Locker | New Locker | Picture of 15 of the 19 |
With all those symptoms, I'm going to say you're getting too much voltage to the bulb, causing it to burn out prematurely. I'd check all my connections for corrosion and, possibly, some cracks in the wire shielding, or, wires that are just about to break, to start with.
thanks guys just got back from a trip so ill go out and try those ideas today. ill get back with you.
Your headlights don't have much of a social life!
Check the voltage at the alternator/battery after the car has been running for a while. Rev the engine to ~3-4k rpm and measure the voltage - if it is above 14.2 volts, you have an alternator problem - this is potentially deadly to all your onboard electronics - TCU, ECU, door lock module, security module, Radio etc.
Another possibility for bulbs to go out is excessive vibration - are the bulbs/housing properly attached? Do you still have any tires attached to your wheels :-) |
