disappearing brake fluid
i have a problem that has been bothering me for a while and i can't figure it out. i refill my brake fluid once a week because it slowly goes down to the low line. i have looked my brakes up and down and no leaks. i really don't know where the fluid is going, also the pedal pressure is fine. and finally, my brakes used to shudder then sink and then the problem just gradually went away. any ideas ?
I has teh FWD LS-L |
Re: disappearing brake fluid
Did you check under the drivers side dash? You can follow your brake pedal up to see where it connects the rod into the master cylinder. They tend to leak after the inner seals age and go bad.
no i have not check that, but dosn't that mean there would be fluid leaking inside the car ?
Yes, it should show along the rod connecting the pedal to the master cylinder, and along the bottom of the MC and below.... you may need to use a white paper towel and dab it to see, since (clean) brake fluid is nearly transparent.
Chris "A person convinced against their will, is of the same opinion still" New?? Find the downloadable SVX Online Service Manual Here RECOMMENDED READING for newer SVX owners Here some cool info if not fully accurate. Last edited by SoCal LS-L; 07-31-2010 at 08:40 AM. |
my brake fluid is pretty crappy.
Actually, the master cylinder is bolted to the vacuum booster assembly , so if the seal leaks, [depending on the type of booster] the fluid can enter the manifold and get burned, thus no signs of leakage.
http://www.abcauto.com/MessageCenter...x?ContentID=13 Last edited by ZMan; 07-31-2010 at 06:39 PM. |
