extremely weird problem??? MAF? ECU?
My car showed all the classic signs of a bad mass air flow sensor it would initialy stall and start right back up and i would go out and tap on the maf sensor and it would seem to fix the issue. So i picked up a maf sensor and put it on at the same time i figured i'd remove the resonator on the intake after all that i took it for a drive and was extremely dissapointed. It seems i have lost quite a bit of low end power (this might just be my imagination) but the next issue is not in my head i floor it and the power light goes on I figure it will pull right to redline and shift.....it doesn't it goes to about 5200 rpm's and acts like a rev limiter kicks in....it won't shift to the next gear and it just sputters?????? I got back home and figured it was the ecu (stock) needed to be erased so i unhooked the battery and tried again......Same results.....now i'm pissed so i get back home and figure the maf sensor i put in was worse than the one i had...put the old one back in and still it is doing the same thing.
Everything was working fine before i started messing with it (aside from the occasional stall) no problems shifting at all. When I start it I have no flashing Power light. What the hell did I do? Did I screw up the ecu? I was planning on upgrading it anyway but not until I got My Koni's and Motorsport springs on this week. Any Ideas |
I would check your coils, your TPS, and in worse case senario, timing chain.
Patrick 1995 Ebony Pearl. S.N. 0001 "Araby" JDM Power Mode Switch, Integrated GPS/Video Player 6Xk Miles. 1992 Teal - Sold to Mysvxrocks [SIGPIC][/SIGPIC] |
Could you have skipped a tooth on the timing belt? Maybe that isn't it, but don't rule it out.
I had the same problem... Is it hard to get the car going like it has a miss under load??
Tom |
On the basis of logic, it could be that you have two faulty MAF sensors. Fault finding by interchanging components, even if the replacement is new, has the danger of this possibility. Not an encouraging suggestion I know, but you should take this into account. It would appear that you have done nothing which should damage the ECU.
Could it be a leak in the air intake between the MAF and the throttle body? Did you pull any of the pipes off when you changed the MAF?
It sounds to me like one of your cats has disintegrated and the exhaust gas is unable to get away.
So now i've gone out this morning to start it and it cranks but won't start.
is it fuel? electrical? mechanical? ???? |
My mechanic is tearing into it as we speak....I'm afraid to see the bill Any Idea what would have caused this? |
